Точно, одиночный ванос, но на каждую голову по комплекту
M62TUB44
In 09.1998, BMW introduced the M62TUB44 which included the VANOS system and an electronically actuated throttle. Although the M62 never received double VANOS, there is some confusion because there is single VANOS on each bank, but only on the intake valve timing, not the exhaust valves. Adding to the confusion is the fact that the M52 6-cilinder did receive an upgrade to double VANOS with the TUB upgrade.
210 kW (286 PS; 282 hp) and 440 N·m (325 lb·ft) / Electronic Throttle -SINGLE vanos;the M5 S62 was the first BMW V8 (and only E39 V8) with dual vanos. In 2002, the power was increased from 210 kW (286 PS; 282 hp) to 216 kW (294 PS; 290 hp) while torque remained the same.
1998-2003 E39 540i
1999-2001 E38 740i/740iL
1999-2003 E53 X5 4.4i
2003-2005 Land Rover Range Rover 4.4
2000-2004 Morgan Aero 8[1]
http://en.wikipedia....MW_M62#M62TUB44
