First off, it has 10 speakers (supposedly) although I have only seen 8 discussed in the forum I belong to. Maybe I was wrong about the subwoofer, because no one had mentioned it. It sure sounds like there’s one, though! (Tony: Valery, can you help?) The only major difference I remember from my first M3 without the upgrade, is the speakers in the front kick panels (granted it’s been 2 and a half years since that car, but I don’t remember any speakers down there), the HIFI switch that turns on an amplifier located in the left side of the trunk, next to the shock tower, and the different speakers with Harmon Kardon (HK) on the speaker shield.
The biggest problem with them is that the mid-range speakers in the front doors are prone to self-destruction at relatively low volume levels. The largest contributing factor is the automatic volume adjustment as the car gains speed (Tony: Wow! that’s a cool feature, isn’t it?). I blew my own that way! Adjust the volume level in the driveway, make it onto the freeway, and KA-POP!
BTW, if you have that annoying feature, I just learned how to fix it while I was researching the Harmon Kardon (HK) stereo. First, you start with the stereo off. Turn it on, and hold the "m" button for approx. 10 sec. The serial # of the radio should appear on the screen. Once it does, use the + and - buttons until you see GAL 1-6 . Then use the < and > buttons to adjust it up or down. 1 is the lowest change, and 6 vice versa. I believe that should also work on British BMW’s as well, even though it was explained for an American M3.
These are some photos of the Harmon Kardon audio system:
E36 Harmon Kardon Audio System
Автор
DarkBMW
, авг 06 2008 12:54
Сообщений в теме: 7
Отправлено 06 Август 2008 - 12:54
Отправлено 06 Август 2008 - 12:59
и чего тут написано ? на французском нет ? )))) но лучше на русском , беларуском, польском на худой конец ...)))
Отправлено 06 Август 2008 - 01:12
Перевод: английский (Автоматически определен) » русский
Во-первых, она имеет 10 ораторов (предположительно), хотя я видел только 8 обсуждаться в форуме мне принадлежат. Может быть, я был неправ по поводу сабвуфера, потому что никто не упомянул о ней. Он уверен звучит как есть одна, хотя! (Тони: Валерий, вы можете помочь?) Единственный из основных различий я помню моего первого M3 без обновления, является выступающих в штрафной передней панели (предоставлен это было 2 с половиной лет с тех пор, что автомобиль, но я дону 'Т вспомнить каких-либо выступавших там вниз), HIFI, что переключатель включается усилитель, расположенных в левой части ствола, рядом с башней шок, и разные ораторы с Хармон Kardon (HK) о оратора shield.The самая большая проблема с ними заключается в том, что середину круга выступающих в передних дверей склонны к самоуничтожению при относительно низких уровнях громкости. Крупнейшим фактором является автоматической регулировки громкости, как автомобиль прибыль скорость (Тони: Wow! Это здорово функция, не правда ли?). Я подорвал себя лично, что путь! Регулировка громкости в driveway, внести его на автостраду, и Ка-POP! BTW, если у вас есть возможность, что раздражает, я только что узнал о том, как исправить ее, пока я был исследования Хармон Kardon (HK) стерео. Во-первых, вы начинаете с стерео удалиться. Поверните его и держите "м" кнопка для прибл. 10 сек. Серийный
Отправлено 06 Август 2008 - 01:21
Ещё
Отправлено 06 Август 2008 - 01:30
Лёша, hotlinking is not allowed. Короче аттачи твои не открываются
Отправлено 06 Август 2008 - 01:32
Поэтому я и повесил фотки.
По теме... сабвуфер устанавливался в кабриолеты.
Отправлено 06 Август 2008 - 10:04
у меня в е36 стояла такая система. для авто 97гв оч даже прилично играла. желания заменить систему не возникало)
Отправлено 06 Август 2008 - 10:28
Повезлоу меня в е36 стояла такая система. для авто 97гв оч даже прилично играла. желания заменить систему не возникало)
А я вот ищу такую для своей Е36.
P.S. а кнопочка HiFi была?
