Ошибки
Сообщений в теме: 22
#1 zevszc
zevszc
  • 17 сообщений
Отправлено 02 Июнь 2012 - 08:05
Может кто подскажет, что нибудь по ошибкам? :rolleyes: Спасибо
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 05/21/12 20:04:19 ECU: MRS4 JobStatus: OKAY Variant: MRS4-------------------------------------------------------------
RESULT: 1 errors in error memory !-------------------------------------------------------------
3 Ignition circuit ZK2 / Belt tensioner Passenger
Error frequency : 54
Error not currently present Resistance too large Sporadic error =============================================================
Date: 05/21/12 20:29:25 ECU: EWS3 JobStatus: OKAY Variant: EWS3-------------------------------------------------------------
RESULT: 6 errors in error memory !-------------------------------------------------------------
15 power on reset
Error frequency : 31
Static error-------------------------------------------------------------
19 toleration of changing code increased with key # 1
3 toleration of changing code increased with key # 0
Error frequency : 14
Sporadic error-------------------------------------------------------------
16 key number 1 not valid because of wrong identification
17 key number 1 not valid because of wrong password
18 key number 1 not valid because of wrong changeing code
Error frequency : 3
Date: 05/21/12 20:46:58 ECU: IHKA46_2 JobStatus: OKAY Variant: IHKA46_2-------------------------------------------------------------
23 Auxiliary water pump
Error frequency : 255
Short circuit to ground Error present
Errorcode: 17 42 FF 3F 75 93 08 10 03 85 =============================================================
Date: 05/21/12 20:56:12 ECU: KOMBI46 JobStatus: OKAY Variant: KOMBI46-------------------------------------------------------------
RESULT: 4 errors in error memory !-------------------------------------------------------------
249 no CAN ID ASC3
Open circuit Error present Sporadic error-------------------------------------------------------------
199 left lever-type sensor
Error frequency : 0
Short circuit to batt+ Sporadic error-------------------------------------------------------------
140 Clamp R
Error frequency : 0
Open circuit Sporadic error-------------------------------------------------------------
215 right lever-type sensor
Error frequency : 0
Short circuit to batt+ Sporadic error =============================================================
Date: 05/21/12 21:00:32 ECU: LSZ_2 JobStatus: OKAY Variant: LSZ_2-------------------------------------------------------------
RESULT: 3 errors in error memory !-------------------------------------------------------------
19 diagnose-lead U10 defect
Error frequency : 12
Error not present-------------------------------------------------------------
34 VHAC, front load sensor short-circuit to ground
36 VHAC, rear load sensor short-circuit to ground
Error frequency : 1
Error not present =============================================================
Date: 05/21/12 21:06:34 ECU: XENON_L JobStatus: OKAY Variant: XENON_L-------------------------------------------------------------
RESULT: 2 errors in error memory !-------------------------------------------------------------
41 head-lights-wiring or cable to headlights high-ohmic
Error frequency : 1
Error present-------------------------------------------------------------
42 clamp 15 < 7,5 Volt
Error frequency : 1
Error present =============================================================
Date: 05/21/12 21:08:59 ECU: ZKE5 JobStatus: OKAY Variant: ZKE5-------------------------------------------------------------
66 Anti-theft alarm system: Interior protection
Error frequency : 4
Sporadic error
Errorcode: 42 04-------------------------------------------------------------
61 Central locking system: Short circuit or Open circuit at Motor Tailgate
Error frequency : 4
Sporadic error
Errorcode: 3D 04-------------------------------------------------------------
7 Anti-theft alarm system: Siren, Radio interior protection, Tilt alarm sensor or Wire STDWA Short circuit to ground or Open circuit
Error frequency : 3
Sporadic error
Errorcode: 07 03 =============================================================
F E H L E R S P E I C H E R L E S E N ---------------------------------------
Datum: 21.05.2012 21:14:40 ECU: DSC_MK60 JobStatus: OKAY Variante: DSC_MK60-------------------------------------------------------------
ERGEBNIS: 3 Fehler im Fehlerspeicher !-------------------------------------------------------------
5DF4 wiring supply voltage < 9 Volt
Fehlerhäufigkeit: 1 Logistikzähler : 1
Kilometerstand 212010 km Vehicle speed 56.00 km/h Brake light switch 0.00 0/1 switch brake fluid level 0.00 0/1 ASC/DSC_aktive (status of ASC/DSC_switch) 1.00 0/1 brake pressure identified 0.00 0/1 ABS-active 0.00 0/1 ASC-active (BMR) 0.00 0/1 ASC-active (AMR) 0.00 0/1 GMR-active (GMR) 0.00 0/1 GMR-active (MMR) 0.00 0/1 CBC-active 0.00 0/1 MSR-active 0.00 0/1 TDR-active 0.00 0/1 SDR-active 0.00 0/1 DBC-active 0.00 0/1 RTA active 1.00 0/1 Run-Up Mode 1.00 0/1
No matching error symptom Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up
Fehlercode: 5D F4 20 01 01 52 D1 38 08 00 0C-------------------------------------------------------------
5E1A CAN DME/DDE Signal Error
Fehlerhäufigkeit: 7 Logistikzähler : 1
Kilometerstand 211680 km Vehicle speed 0.00 km/h Brake light switch 1.00 0/1 switch brake fluid level 0.00 0/1 ASC/DSC_aktive (status of ASC/DSC_switch) 1.00 0/1 brake pressure identified 0.00 0/1 ABS-active 0.00 0/1 ASC-active (BMR) 0.00 0/1 ASC-active (AMR) 0.00 0/1 GMR-active (GMR) 0.00 0/1 GMR-active (MMR) 0.00 0/1 CBC-active 0.00 0/1 MSR-active 0.00 0/1 TDR-active 0.00 0/1 SDR-active 0.00 0/1 DBC-active 0.00 0/1 RTA active 1.00 0/1 Run-Up Mode 0.00 0/1
No matching error symptom Test conditions fulfilled Error not present now, but already stored Error would cause a warning lamp to light up
Fehlercode: 5E 1A A0 07 01 52 B0 00 09 00 04-------------------------------------------------------------
5E19 CAN DME/DDE, engine torque not adjustable
Fehlerhäufigkeit: 4 Logistikzähler : 1
Fehlercode: 5E 19 A0 04 01 52 B0 00 09 00 04 =============================================================
#2 DimaSmile
DimaSmile
  • 1 124 сообщений
Отправлено 03 Июнь 2012 - 12:00
обалдеть сколько ошибок.И это все за один присест?!
#3 zevszc
zevszc
  • 17 сообщений
Отправлено 03 Июнь 2012 - 04:25
да за 1 раз по разным блокам :ph34r:
#4 tmac
tmac
  • 838 сообщений
Отправлено 03 Июнь 2012 - 07:56
автор, ты хоть сам пробовал читать, что тут написано? загоняешь ошибку в гугл и читаешь. не надо постить такие мега отчеты, почитай вначале сам, потом спроси куда копать дальше, какой блок заменить или датчик, где он находится. даже банально переведи с английского название ошибки и уже 80 процентов поймешь, что за она. А еще лучше, если ты уже купил кабель, то поставь ДИС, там все на русском.
#5 zevszc
zevszc
  • 17 сообщений
Отправлено 03 Июнь 2012 - 12:10
спасибо. не устал писать?
#6 -Markiz-
-Markiz-
  • 1 037 сообщений
Отправлено 03 Июнь 2012 - 12:48
по сравнению с Вашим первым постом это сущий пустяк,
вместо того что бы задавать ненужные вопросы, лучше воспользоваться советом
#7 newbie
newbie
  • 1 128 сообщений
Отправлено 03 Июнь 2012 - 12:50
преднатяжитель ремня безопасности пассажира
где-то коротит и пробивает на массу водяная помпа судя по всему, это по климе
15 power on reset
Error frequency : 3
249 no CAN ID ASC3
Error frequency : 0
140 Clamp R
Error frequency : 0
Error frequency : 0
по этим не уверен, но скорее всего проблема в ключах и евс. ?может контактная группа окислилась\подгорела в рулевой клонке?
Error frequency : 1
Error frequency : 1
Error frequency : 1
на машине ксенон? проверяй датчики угла наклона
второе хз...что-то с повышенным сопротивлением в проводке на ксенон
з.ы. автор, тебе все правильно написали :down: , не ленись пользоваться поиском. большинство ошибок уже не 1 раз обсуждались и расписывались людьми. :excl: :kos:
другое дело если ты действительно не нашел ответа на какие-то вопросы. :kos:
поддерживаю :good:
#8 zevszc
zevszc
  • 17 сообщений
Отправлено 03 Июнь 2012 - 01:20
поддерживаю :good:
спасибо за помощь. про помпу и про ремень я нашел. просто по другим думаю может кто подскажет. не ленюсь искал.решил может кто поможет, а чуть что так сразу поиск. лучше пройти мимо. чем писать
#9 newbie
newbie
  • 1 128 сообщений
Отправлено 03 Июнь 2012 - 01:23
так ведь и нужно было задать вопросы по конкретным интересующим тебя ошибкам, на которые ты не нашел ответа, зачем было весь отчет из инпы сбрасывать?)
#10 sharman
sharman
  • 14 659 сообщений
Отправлено 03 Июнь 2012 - 01:44
тут все тебе по делу написали
#11 Nintendo
Nintendo
  • 103 сообщений
Отправлено 03 Июнь 2012 - 02:45
Мдаа...а для чего форум тогда, если гугл все знает?
#12 zevszc
zevszc
  • 17 сообщений
Отправлено 03 Июнь 2012 - 09:14
Ну понимаешь когда люди начинают много знать им начинает тяжело это говорить другим. Вернее в лом. проще на гугл послать)))). И проблема, что никто не пропустит,а сразу туда на поисковик пошлют
#13 DimaSmile
DimaSmile
  • 1 124 сообщений
Отправлено 03 Июнь 2012 - 10:16
+100)))
#14 Fare
Fare
  • 512 сообщений
Отправлено 03 Июнь 2012 - 10:24
Коды неисправностей стандарта OBDII P0 1XX FUEL AND AIR METERING Измерители топлива и воздуха PO 100 MAF or VAF CIRCUIT MALFUNCTION Неисправность цепи датчика расхода воздуха PO 101 MAF or VAF CIRCUIT RANGE/PERF PROBLEM Выход сигнала из допустимого диапазона PO 102 MAF or VAF CIRCUIT LOW INPUT Низкий уровень выходного сигнала PO 103 MAF or VAF CIRCUIT HIGH INPUT Высокий уровень выходного сигнала PO 105 MAP/BARO CIRCUIT MALFUNCTION Неисправность датчика давления воздуха PO 106 MAP/BARO CIRCUIT RANGE/PERF PROBLEM Выход сигнала из допустимого диапазона PO 107 MAP/BARO CIRCUIT LOW INPUT Низкий уровень выходного сигнала PO 108 MAP/BARO CIRCUIT HIGH INPUT Высокий уровень выходного сигнала PO 110 IAT CIRCUIT MALFUNCTION Неисправность датчика температуры всасываемого воздуха PO 111 IAT RANGE/PERF PROBLEM Выход сигнала из допустимого диапазона PO 112 IAT CIRCUIT LOW INPUT Низкий уровень выходного сигнала PO 113 IAT CIRCUIT HIGH INPUT Высокий уровень выходного сигнала PO 115 ECT CIRCUIT MALFUNCTION Неисправность датчика температуры охлаждающей жидкости PO 116 ECT RANGE/PERF PROBLEM Выход сигнала из допустимого диапазона PO 117 ECT CIRCUIT LOW INPUT Низкий уровень выходного сигнала PO 118 ECT CIRCUIT HIGH INPUT Высокий уровень выходного сигнала PO 120 TPS SENSOR A CIRCUIT MALFUNCTION Неисправность датчика положения дроссельной заслонки PO 121 TPS SENSOR A RANGE/PERF PROBLEM Выход сигнала из допустимого диапазона PO 122 TPS SENS A CIRCUIT LOW INPUT Низкий уровень выходного сигнала PO 123 TPS SENS A CIRCUIT HIGH INPUT Высокий уровень выходного сигнала PO 125 LOW ECT FOR CLOSED LOOP FUEL CONTROL Низкая температуры охлаждающей жид. для упр.по замкн.контуру PO 130 02 SENSOR B1 S1 MALFUNCTION Датчик О2 В1 S1 несправен(Банк1) PO 131 02 SENSOR B1 S1 LOW VOLTAGE Датчик О2 В1 S1 имеет низкий уровень сигнала PO 132 02 SENSOR B1 S1 HIGH VOLTAGE Датчик О2 В1 S1 имеет высокий уровень сигнала PO 133 02 SENSOR B1 S1 SLOW RESPONSE Датчик О2 В1 S1 имеет медленный отклик на обогащение/обеднение PO 134 02 SENSOR B1 S1 CIRCUIT INACTIVE Цепь датчика О2 В1 S1 пассивна PO 135 02 SENSOR B1 S1 HEATER MALFUNCTION Нагреватель датчика О2 В1 S1 несправен PO 136 02 SENSOR B1 S2 MALFUNCTION Датчик О2 В1 S2 несправен PO 137 02 SENSOR B1 S2 LOW VOLTAGE Датчик О2 В1 S2 имеет низкий уровень сигнала PO 138 02 SENSOR B1 S2 HIGH VOLTAGE Датчик О2 В1 S2 имеет высокий уровень сигнала PO 139 02 SENSOR B1 S2 SLOW RESPONSE Датчик О2 В1 S2 имеет медленный отклик на обогащение/обеднение PO 140 02 SENSOR B1 S2 CIRCUIT INACTIVE Цепь датчика О2 В1 S2 пассивна PO 141 02 SENSOR B1 S2 HEATER MALFUNCTION Нагреватель датчика О2 В1 S2 несправен PO 142 02 SENSOR B1 S3 MALFUNCTION Датчик О2 В1 S3 несправен PO 143 02 SENSOR B1 S3 LOW VOLTAGE Датчик О2 В1 S3 имеет низкий уровень сигнала PO 144 02 SENSOR B1 S3 HIGH VOLTAGE Датчик О2 В1 S3 имеет высокий уровень сигнала PO 145 02 SENSOR B1 S3 SLOW RESPONSE Датчик О2 В1 S3 имеет медленный отклик на обогащение/обеднение PO 146 02 SENSOR B1 S3 CIRCUIT INACTIVE Цепь датчика О2 В1 S3 пассивна PO 147 02 SENSOR B1 S3 HEATER MALFUNCTION Нагреватель датчика О2 В1 S3 несправен PO 150 02 SENSOR B2 S1 CIRCUIT MALFUNCTION Датчик О2 В2 S1 несправен (Банк2) PO 151 02 SENSOR B2 S1 CKT LOW VOLTAGE Датчик О2 В2 S1 имеет низкий уровень сигнала PO 152 02 SENSOR B2 S1 CKT HIGH VOLTAGE Датчик О2 В2 S1 имеет высокий уровень сигнала PO 153 02 SENSOR B2 S1 CKT SLOW RESPONSE Датчик О2 В2 S1 имеет медленный отклик на обогащение/обеднение PO 154 02 SENSOR B2 S1 CIRCUIT INACTIVE Цепь датчика О2 В2 S1 пассивна PO 155 02 SENSOR B2 S1 HTR CKT MALFUNCTION Нагреватель датчика О2 В2 S1 несправен PO 156 02 SENSOR B2 S2 CIRCUIT MALFUNCTION Датчик О2 В2 S2 несправен PO 157 02 SENSOR B2 S2 CKT LOW VOLTAGE Датчик О2 В2 S2 имеет низкий уровень сигнала PO 158 02 SENSOR B2 S2 CKT HIGH VOLTAGE Датчик О2 В2 S2 имеет высокий уровень сигнала PO 159 02 SENSOR B2 S2 CKT SLOW RESPONSE Датчик О2 В2 S2 имеет медленный отклик на обогащение/обеднение PO 160 02 SENSOR B2 S2 CIRCUIT INACTIVE Цепь датчика О2 В2 S2 пассивна PO 161 02 SENSOR B2 S2 HTR CKT MALFUNCTION Нагреватель датчика О2 В2 S2 несправен PO 162 02 SENSOR B2 S3 CIRCUIT MALFUNCTION Датчик О2 В2 S3 несправен PO 163 02 SENSOR B2 S3 CKT LOW VOLTAGE Датчик О2 В2 S3 имеет низкий уровень сигнала PO 164 02 SENSOR B2 S3 CKT HIGH VOLTAGE Датчик О2 В2 S3 имеет высокий уровень сигнала PO 165 02 SENSOR B2 S3 CKT SLOW RESPONSE Датчик О2 В2 S3 имеет медленный отклик на обогащение/обеднение PO 166 02 SENSOR B2 S3 CIRCUIT INACTIVE Цепь датчика О2 В2 S3 пассивна PO 167 02 SENSOR B2 S3 HTR CKT MALFUNCTION Нагреватель датчика О2 В2 S3 несправен PO 170 BANK 1 FUEL TRIM MALFUNCTION Утечка топлива из топливной системы блока №1 PO 171 BANK 1 SYSTEM TOO LEAN Блок цилиндров №1 беднит (возможно подсос воздуха) PO 172 BANK 1 SYSTEM TOO RICH Блок цилиндров №1 богатит (возможно неполное закрытие форсунки) PO 173 BANK 2 FUEL TRIM MALFUNCTION Утечка топлива из топливной системы блока №2 PO 174 BANK 2 SYSTEM TOO LEAN Блок цилиндров №2 беднит (возможно подсос воздуха) PO 175 BANK 2 SYSTEM TOO RICH Блок цилиндров №2 богатит (возможно неполное закрытие форсунки) PO 176 FUEL COMPOSITION SENSOR MALFUNCTION Датчик выброса СНх неисправен PO 177 FUEL COMPOSITION SENS CKT RANGE/PERF Сигнал датчика выходит из допустимого диапазона PO 178 FUEL COMPOSITION LOW INPUT Низкий уровень сигнала датчика СНх PO 179 FUEL COMPOSITION HIGH INPUT Высокий уровень сигнала датчика СНх PO 180 FUEL TEMP SENSOR A CIRCUIT MALFUNCTION Цепь датчика температуры топлива «А» неисправна PO 181 FUEL TEMP SENSOR A CIRCUIT RANGE/PERF Сигнал датчика «А» выходит из допустимого диапазона PO 182 FUEL TEMP SENSOR A LOW INPUT Низкий сигнал датчика температуры топлива «А» PO 183 FUEL TEMP SENSOR A HIGH INPUT Высокий сигнал датчика температуры топлива «А» PO 185 FUEL TEMP SENSOR B CIRCUIT MALFUNCTION Цепь датчика температуры топлива «В» неисправна PO 186 FUEL TEMP SENSOR RANGE/PERF Сигнал датчика «В» выходит из допустимого диапазона PO 187 FUEL TEMP SENSOR B LOW INPUT Низкий сигнал датчика температуры топлива «В» PO 188 FUEL TEMP SENSOR B HIGH INPUT Высокий сигнал датчика температуры топлива «В» PO 190 FUEL RAIL PRESSURE CIRCUIT MALFUNCTION Цепь датчика давления топлива в топливной рампе неисправна PO 191 FUEL RAIL CIRCUIT RANGE/PERF Сигнал датчика выходит из допустимого диапазона PO 192 FUEL RAIL PRESSURE LOW INPUT Низкий сигнал датчика давления топлива PO 193 FUEL RAIL PRESSURE HIGH INPUT Высокий сигнал датчика давления топлива PO 194 FUEL RAIL PRESSURE CKT INTERMITTENT Сигнал датчика давления топлива перемежающийся PO 195 ENGINE OIL TEMP SENSOR MALFUNCTION Цепь датчика температуры масла в двигателе неисправна PO 196 ENGINE OIL TEMP SENSOR RANGE/PERF Сигнал датчика выходит из допустимого диапазона PO 197 ENGINE OIL TEMP SENSOR LOW Низкий сигнал датчика температуры масла PO 198 ENGINE OIL TEMP SENSOR HIGH Высокий сигнал датчика температуры масла PO 199 ENGINE OIL TEMP SENSOR INTERMITTENT Сигнал датчика температуры масла перемежающийся PO 2XX FUEL AND AIR METERING PO 200 INJECTOR CIRCUIT MALFUNCTION Цепь управления форсункой неисправна PO 201 INJECTOR CIRCUIT MALFUNCTION CYL 1 Цепь управления форсункой цилиндра №1 неисправна PO 202 INJECTOR CIRCUIT MALFUNCTION CYL 2 Цепь управления форсункой цилиндра №2 неисправна PO 203 INJECTOR CIRCUIT MALFUNCTION CYL 3 Цепь управления форсункой цилиндра №3 неисправна PO 204 INJECTOR CIRCUIT MALFUNCTION CYL 4 Цепь управления форсункой цилиндра №4 неисправна PO 205 INJECTOR CIRCUIT MALFUNCTION CYL 5 Цепь управления форсункой цилиндра №5 неисправна PO 206 INJECTOR CIRCUIT MALFUNCTION CYL 6 Цепь управления форсункой цилиндра №6 неисправна PO 207 INJECTOR CIRCUIT MALFUNCTION CYL 7 Цепь управления форсункой цилиндра №7 неисправна PO 208 INJECTOR CIRCUIT MALFUNCTION CYL 8 Цепь управления форсункой цилиндра №8 неисправна PO 209 INJECTOR CIRCUIT MALFUNCTION CYL 9 Цепь управления форсункой цилиндра №9 неисправна PO 210 INJECTOR CIRCUIT MALFUNCTION CYL 10 Цепь управления форсункой цилиндра №10 неисправна PO 211 INJECTOR CIRCUIT MALFUNCTION CYL 11 Цепь управления форсункой цилиндра №11 неисправна PO 212 INJECTOR CIRCUIT MALFUNCTION CYL 12 Цепь управления форсункой цилиндра №12 неисправна PO 213 COLD START INJ N0.1 MALFUNCTION Цепь управления форсункой холодного старта №1 неисправна PO 214 COLD START INJ N0.2 MALFUNCTION Цепь управления форсункой холодного старта №2 неисправна PO 215 ENGINE SHUTOFF SOL MALFUNCTION Соленоид выключения двигателя неисправен PO 216 INJ TIMING CONTROL CIRCUIT MALFUNCTION Цепь контроля времени впрыска неисправна PO 217 ENGINE OVERTEMP CONDITION Двигатель находится в перегретом состоянии PO 218 TRANSMISSION OVERTEMP CONDITION Трансмиссия находится в перегретом состоянии PO 219 ENGINE OVERSPEED CONDITION Двигатель перекручен PO 220 TPS SENSOR B CIRCUIT MALFUNCTION Неисправность датчика положения дроссельной заслонки «В» PO 221 TPS SENSOR B CIRCUIT RANGE/PERF Выход сигнала из допустимого диапазона PO 222 TPS SENSOR B LOW INPUT Низкий уровень выходного сигнала датчика «В» PO 223 TPS SENSOR B HIGH INPUT Высокий уровень выходного сигнала датчика «В» PO 224 TPS SENSOR B CKT INTERMITTENT Сигнал датчика «В» перемежающийся PO 225 TPS SENSOR C CIRCUIT MALFUNCTION Неисправность датчика положения дроссельной заслонки «С» PO 226 TPS SENSOR C CIRCUIT RANGE/PERF Выход сигнала из допустимого диапазона PO 227 TPS SENSOR C LOW INPUT Низкий уровень выходного сигнала датчика «С» PO 228 TPS SENSOR C HIGH INPUT Высокий уровень выходного сигнала датчика «С» PO 229 TPS SENSOR C CKT INTERMITTENT Сигнал датчика «С» перемежающийся PO 230 FUEL PUMP PRIMARY CIRCUIT MALFUNCTION Первичная цепь бензонасоса (управление реле бензонас.) неисправна PO 231 FUEL PUMP SECONDARY CIRCUIT LOW Вторичная цепь бензонасоса имеет постоянно низкий уровень PO 232 FUEL PUMP SECONDARY CIRCUIT HIGH Вторичная цепь бензонасоса имеет постоянно высокий уровень PO 233 FUEL PUMP SECONDARY CKT INTERMITTENT Вторичная цепь бензонасоса имеет перемежающийся уровень PO 235 TURBO BOOST SENSOR A CIRCUIT MALFUNCTION Цепь датчика давления турбо-наддува «А» неисправен PO 236 TURBO BOOST SENSOR A CIRCUIT RANGE/PERF Сигнал с датчика турбины «А» выходит из допустимого диапазона PO 237 TURBO BOOST SENSOR A CIRCUIT LOW Сигнал с датчика турбины «А» имеет постоянно низкий уровень PO 238 TURBO BOOST SENSOR A CIRCUIT HIGH Сигнал с датчика турбины «А» имеет постоянно высокий уровень PO 239 TURBO BOOST SENSOR B CIRCUIT MALFUNCTION Цепь датчика давления турбо-наддува «Б» неисправен PO 240 TURBO BOOST SENSOR B CIRCUIT RANGE/PERF Сигнал с датчика турбины «Б» выходит из допустимого диапазона PO 241 TURBO BOOST SENSOR B CIRCUIT LOW Сигнал с датчика турбины «Б» имеет постоянно низкий уровень PO 242 TURBO BOOST SENSOR B CIRCUIT HIGH Сигнал с датчика турбины «Б» имеет постоянно высокий уровень PO 243 TURBO WASTEGATE A SOLENOID MALFUNC Соленоид затвора выхлопных газов турбины «А» неисправен PO 244 TURBO WASTEGATE A SOLENOID RANGE/PERF Сигнал соленоида турбины «А» выходит из допустимого диапазона PO 245 TURBO WASTEGATE A SOLENOID LOW Соленоид выхлопных газов турбины «А» всегда закрыт PO 246 TURBO WASTEGATE A SOLENOID HIGH Соленоид выхлопных газов турбины «А» всегда открыт PO 247 TURBO WASTEGATE B SOLENOID MALFUNC Соленоид выхлопных газов турбины «В» неисправен PO 248 TURBO WASTEGATE B SOLENOID RANGE/PERF Сигнал соленоида турбины «В» выходит из допустимого диапазона PO 249 TURBO WASTEGATE B SOLENOID LOW Соленоид выхлопных газов турбины «В» всегда закрыт PO 250 TURBO WASTEGATE B SOLENOID HIGH Соленоид выхлопных газов турбины «В» всегда открыт PO 251 INJECTION PUMP A ROTOR/CAM MALFUNCTION Насос впрыска турбины «А» неисправен PO 252 INJECTION PUMP A ROTOR/CAM RANGE/PERF Сигнал насоса впрыска турбины «А» выходит из доп. диапазона PO 253 INJECTION PUMP A ROTOR/CAM LOW Сигнал насоса впрыска турбины «А» имеет низкий уровень PO 254 INJECTION PUMP A ROTOR/CAM HIGH Сигнал насоса впрыска турбины «А» имеет высокий уровень PO 255 INJECTION PUMP A ROTOR/CAM INTERMIT Сигнал насоса впрыска турбины «А» перемежающийся PO 256 INJECTION PUMP B ROTOR/CAM MALFUNCTION Насос впрыска турбины «В» неисправен PO 257 INJECTION PUMP B ROTOR/CAM RANGE/PERF Сигнал насоса впрыска турбины «В» выходит из доп. диапазона PO 258 INJECTION PUMP B ROTOR/CAM LOW Сигнал насоса впрыска турбины «В» имеет низкий уровень PO 259 INJECTION PUMP B ROTOR/CAM HIGH Сигнал насоса впрыска турбины «В» имеет высокий уровень PO 260 INJECTION PUMP B ROTOR/CAM INTERMIT Сигнал насоса впрыска турбины «В» перемежающийся PO 261 INJ CYLINDER 1 CIRCUIT LOW Форсунка 1-ого цилиндра замкнута на землю PO 262 INJ CYLINDER 1 CIRCUIT HIGH Форсунка 1-ого цилиндра оборвана или замкнута на +12В PO 263 CYLINDER 1 CONTRIB/BAL FAULT Драйвер форсунки 1-ого цилиндра неисправен PO 264 INJ CYLINDER 2 CIRCUIT LOW Форсунка 2-ого цилиндра замкнута на землю PO 265 INJ CYLINDER 2 CIRCUIT HIGH Форсунка 2-ого цилиндра оборвана или замкнута на +12В PO 266 CYLINDER 2 CONTRIB/BAL FAULT Драйвер форсунки 2-ого цилиндра неисправен PO 267 INJ CYLINDER 3 CIRCUIT LOW Форсунка 3-го цилиндра замкнута на землю PO 268 INJ CYLINDER 3 CIRCUIT HIGH Форсунка 3-го цилиндра оборвана или замкнута на +12В PO 269 CYLINDER 3 CONTRIB/BAL FAULT Драйвер форсунки 3-го цилиндра неисправен PO 270 INJ CYLINDER 4 CIRCUIT LOW Форсунка 4-ого цилиндра замкнута на землю PO 271 INJ CYLINDER 4 CIRCUIT HIGH Форсунка 4-ого цилиндра оборвана или замкнута на +12В PO 272 CYLINDER 4 CONTRIB/BAL FAULT Драйвер форсунки 4-ого цилиндра неисправен PO 273 INJ CYLINDER 5 CIRCUIT LOW Форсунка 5-ого цилиндра замкнута на землю PO 274 INJ CYLINDER 5 CIRCUIT HIGH Форсунка 5-ого цилиндра оборвана или замкнута на +12В PO 275 CYLINDER 5 CONTRIB/BAL FAULT Драйвер форсунки 5-ого цилиндра неисправен PO 276 INJ CYLINDER 6 CIRCUIT LOW Форсунка 6-ого цилиндра замкнута на землю PO 277 INJ CYLINDER 6 CIRCUIT HIGH Форсунка 6-ого цилиндра оборвана или замкнута на +12В PO 278 CYLINDER 6 CONTRIB/BAL FAULT Драйвер форсунки 6-ого цилиндра неисправен PO 279 INJ CYLINDER 7 CIRCUIT LOW Форсунка 7-ого цилиндра замкнута на землю PO 280 INJ CYLINDER 7 CIRCUIT HIGH Форсунка 7-ого цилиндра оборвана или замкнута на +12В PO 281 CYLINDER 7 CONTRIB/BAL FAULT Драйвер форсунки 7-ого цилиндра неисправен PO 282 INJ CYLINDER 8 CIRCUIT LOW Форсунка 8-ого цилиндра замкнута на землю PO 283 INJ CYLINDER 8 CIRCUIT HIGH Форсунка 8-ого цилиндра оборвана или замкнута на +12В PO 284 CYLINDER 8 CONTRIB/BAL FAULT Драйвер форсунки 8-ого цилиндра неисправен PO 285 INJ CYLINDER 9 CIRCUIT LOW Форсунка 9-ого цилиндра замкнута на землю PO 286 INJ CYLINDER 9 CIRCUIT HIGH Форсунка 9-ого цилиндра оборвана или замкнута на +12В PO 287 CYLINDER 9 CONTRIB/BAL FAULT Драйвер форсунки 9-ого цилиндра неисправен PO 288 INJ CYLINDER 10 CIRCUIT LOW Форсунка 10-ого цилиндра замкнута на землю PO 289 INJ CYLINDER 10 CIRCUIT HIGH Форсунка 10-ого цилиндра оборвана или замкнута на +12В PO 290 CYLINDER 10 CONTRIB/BAL FAULT Драйвер форсунки 10-ого цилиндра неисправен PO 291 INJ CYLINDER 11 CIRCUIT LOW Форсунка 11-ого цилиндра замкнута на землю PO 292 INJ CYLINDER 11 CIRCUIT HIGH Форсунка 11-ого цилиндра оборвана или замкнута на +12В PO 293 CYLINDER 11 CONTRIB/BAL FAULT Драйвер форсунки 11-ого цилиндра неисправен PO 294 INJ CYLINDER 12 CIRCUIT LOW Форсунка 12-ого цилиндра замкнута на землю PO 295 INJ CYLINDER 12 CIRCUIT HIGH Форсунка 12-ого цилиндра оборвана или замкнута на +12В PO 296 CYLINDER 12 CONTRIB/BAL FAULT Драйвер форсунки 12-ого цилиндра неисправен PO 3XX IGNITION SYSTEM OR MISFIRE Система зажигания и пропуски PO 300 RANDOM/MULTIPLE MISFIRE DETECTED Обнаружены случайные/множественные пропуски зажигания PO 301 CYLINDER 1 MISFIRE DETECTED Обнаружены пропуски зажигания в 1-ом цилиндре PO 302 CYLINDER 2 MISFIRE DETECTED Обнаружены пропуски зажигания во 2-ом цилиндре PO 303 CYLINDER 3 MISFIRE DETECTED Обнаружены пропуски зажигания в 3-ем цилиндре PO 304 CYLINDER 4 MISFIRE DETECTED Обнаружены пропуски зажигания в 4-ом цилиндре PO 305 CYLINDER 5 MISFIRE DETECTED Обнаружены пропуски зажигания в 5-ом цилиндре PO 306 CYLINDER 6 MISFIRE DETECTED Обнаружены пропуски зажигания в 6-ом цилиндре PO 307 CYLINDER 7 MISFIRE DETECTED Обнаружены пропуски зажигания в 7-ом цилиндре PO 308 CYLINDER 8 MISFIRE DETECTED Обнаружены пропуски зажигания в 8-ом цилиндре PO 309 CYLINDER 9 MISFIRE DETECTED Обнаружены пропуски зажигания в 9-ом цилиндре PO 310 CYLINDER 10 MISFIRE DETECTED Обнаружены пропуски зажигания в 10-ом цилиндре PO 311 CYLINDER 11 MISFIRE DETECTED Обнаружены пропуски зажигания в 11-ом цилиндре PO 312 CYLINDER 12 MISFIRE DETECTED Обнаружены пропуски зажигания в 12-ом цилиндре PO 320 IGN/DIST RPM CKT INPUT MALFUNCTION Цепь распределителя зажигания неисправна PO 321 IGN/DIST RPM CKT RANGE/PERFORMANCE Сигнал цепи распределителя зажигания выходит за доп. пределы PO 322 IGN/DIST RPM CKT NO SIGNAL Сигнал цепи распределителя зажигания отсутствует PO 323 IGN/DIST RPM CKT INTERMITTENT Сигнал цепи распределителя зажигания перемежающийся PO 325 KNOCK SENSOR 1 CIRCUIT MALFUNCTION Цепь датчика детонации №1 неисправна PO 326 KNOCK SENSOR 1 RANGE/PERFORMANCE Сигнал датчика детонации №1 выходит за допустимые пределы PO 327 KNOCK SENSOR 1 LOW INPUT Сигнал датчика детонации №1 имеет низкий уровень PO 328 KNOCK SENSOR 1 HIGH INPUT Сигнал датчика детонации №1 имеет высокий уровень PO 329 KNOCK SENSOR 1 INTERMITTENT Сигнал датчика детонации №1 перемежающийся PO 330 KNOCK SENSOR 2 CIRCUIT MALFUNCTION Цепь датчика детонации №2 неисправна PO 331 KNOCK SENSOR 2 RANGE/PERFORMANCE Сигнал датчика детонации №2 выходит за допустимые пределы PO 332 KNOCK SENSOR 2 LOW INPUT Сигнал датчика детонации №2 имеет низкий уровень PO 333 KNOCK SENSOR 2 HIGH INPUT Сигнал датчика детонации №2 имеет высокий уровень PO 334 KNOCK SENSOR 2 INTERMITTENT Сигнал датчика детонации №2 перемежающийся PO 335 CRANKSHAFT POSITION SENS A MALFUNC Датчик положения коленчатого вала «А» неисправен PO 336 CRANKSHAFT POS A RANGE/PERFORMANCE Сигнал датчика «А» выходит за допустимые пределы PO 337 CRANKSHAFT POSITION SENSOR A LOW INPUT Сигнал датчика «А» имеет низкий уровень или замкнут на массу PO 338 CRANKSHAFT POSITION SENSOR A HIGH INPUT Сигнал датчика «А» имеет высокий уровень или замкнут на 12В PO 339 CRANKSHAFT POS A SENSOR INTERMITTENT Сигнал датчика «А» перемежающийся PO 340 CAMSHAFT POSITION SENSOR MALFUNCTION Датчик положения распределительного вала неисправен PO 341 CAMSHAFT POSITION RANGE/PERFORMANCE Сигнал датчика выходит за допустимые пределы PO 342 CAMSHAFT POSITION SENSOR LOW INPUT Сигнал датчика имеет низкий уровень или замкнут на массу PO 343 CAMSHAFT POSITION SENSOR HIGH INPUT Сигнал датчика имеет высокий уровень PO 344 CAMSHAFT POSITION SENSOR INTERMITTENT Сигнал датчика перемежающийся PO 350 IGN COIL PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания неисправны PO 351 IGN COIL A PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «А» неисправны PO 352 IGN COIL B PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «B» неисправны PO 353 IGN COIL C PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «C» неисправны PO 354 IGN COIL D PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «D» неисправны PO 355 IGN COIL E PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «E» неисправны PO 356 IGN COIL F PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «F» неисправны PO 357 IGN COIL G PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «G» неисправны PO 358 IGN COIL H PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «H» неисправны PO 359 IGN COIL I PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «I» неисправны PO 360 IGN COIL J PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «J» неисправны PO 361 IGN COIL K PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «K» неисправны PO 362 IGN COIL L PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «L» неисправны PO 370 TIMING REF (HRS) A MALFUNCTION PO 371 TIMING REF (HRS) A TOO MANY PULSES PO 372 TIMING REF (HRS) A TOO MANY PULSES PO 373 TIMING REF (HRS) A INTERMITTENT PULSES PO 374 TIMING REF (HRS) A NO PULSES PO 375 TIMING REF (HRS) B MALFUNCTION PO 376 TIMING REF (HRS) B TOO MANY PULSES PO 377 TIMING REF (HRS) B TOO MANY PULSES PO 378 TIMING REF (HRS) B INTERMITTENT PULSES PO 379 TIMING REF (HRS) B NO PULSES PO 380 GLOW PLUG/HEATER CIRCUIT MALFUNCTION Свеча накаливания или цепь нагрева неисправны PO 381 GLOW PLUG/HEATER INDICATOR MALFUNC Свеча накаливания или индикатор нагрева неисправны PO 385 CRANKSHFT POS SEN B CIRCUIT MALFUNCTION Цепь датчика положения коленчатого вала «В» неисправны PO 386 CRANKSHFT POS SEN B RANGE/PERFORMANCE Сигнал датчика «В» выходит за допустимые пределы PO 387 CRANKSHFT POS SEN B CIRCUIT LOW INPUT Цепь датчика оборвана или замкнута на массу PO 388 CRANKSHFT POS SEN B CIRCUIT HIGH INPUT Цепь датчика замкнута на один из силовых выводов PO 389 CRANKSHFT POS SEN B CIRCUIT INTERMIT Сигнал датчика «В» перемежающийся PO 4XX AUXILIARY EMISSION CONTROLS PO 400 EGR FLOW MALFUNCTION Система рециркуляции отработанных газов неисправна PO 401 EGR FLOW INSUFFICIENT Система рециркуляции отработанных газов неэффективна PO 402 EGR FLOW EXCESSIVE Система рециркуляции отработанных газов избыточна PO 403 EGR CIRCUIT MALFUNCTION Цепь датчика рециркуляции отработанных газов неисправна PO 404 EGR RANGE/PERFORMANCE Сигнал датчика выходит за допустимые пределы PO 405 EGR SENSOR A CIRCUIT LOW Сигнал датчика «А» имеет низкий уровень PO 406 EGR SENSOR A CIRCUIT HIGH Сигнал датчика «А» имеет высокий уровень PO 407 EGR SENSOR B CIRCUIT LOW Сигнал датчика «В» имеет низкий уровень PO 408 EGR SENSOR B CIRCUIT HIGH Сигнал датчика «В» имеет высокий уровень PO 410 SECONDARY AIR INJ SYSTEM MALFUNCTION Система вторичной подачи (впрыска) воздуха неисправна PO 411 SECONDARY AIR INJ INCORRECT FLOW Ошибочный поток проходит через систему вторичной подачи воздуха PO 412 SECONDARY AIR INJ VALVE A MALFUNCTION Клапан системы вторичной подачи воздуха «А» неисправен PO 413 SECONDARY AIR INJ VALVE A OPEN Клапан системы вторичной подачи воздуха «А» всегда открыт PO 414 SECONDARY AIR INJ VALVE A SHORTED Клапан системы вторичной подачи воздуха «А» всегда закрыт PO 415 SECONDARY AIR INJ VALVE B MALFUNCTION Клапан системы вторичной подачи воздуха «В» неисправен PO 416 SECONDARY AIR INJ VALVE B OPEN Клапан системы вторичной подачи воздуха «В» всегда открыт PO 417 SECONDARY AIR INJ VALVE B SHORTED Клапан системы вторичной подачи воздуха «В» всегда закрыт PO 420 CAT SYS EFFIC B1 BELOW THRESHOLD Эффективность системы катализаторов «В1» ниже порога PO 421 WARM UP CAT EFFIC B1 BELOW THRESHOLD Эффективность прогрева катализатора «В1» ниже порога PO 422 MAIN CAT EFFIC B1 BELOW THRESHOLD Эффективность главного катализатора «В1» ниже порога PO 423 HEATED CAT EFFIC B1 BELOW THRESHOLD Эффективность нагревателя катализатора «В1» ниже порога PO 424 HEATED CAT TEMP B1 BELOW THRESHOLD Температура нагревателя катализатора «В2» ниже порога PO 430 CAT SYS EFFIC B2 BELOW THRESHOLD Эффективность системы катализаторов «В2» ниже порога PO 431 WARM UP CAT EFFIC B2 BELOW THRESHOLD Эффективность прогрева катализатора «В2» ниже порога PO 432 MAIN CAT EFFIC B2 BELOW THRESHOLD Эффективность главного катализатора «В2» ниже порога PO 433 HEATED CAT EFFIC B2 BELOW THRESHOLD Эффективность нагревателя катализатора «В2» ниже порога PO 434 HEATED CAT TEMP B2 BELOW THRESHOLD Температура нагревателя катализатора «В2» ниже порога PO 440 EVAP CONTROL SYSTEM MALFUNCTION Контроль системы улавливания паров бензина неисправен PO 441 EVAP CONTROL BAD PURGE FLOW Система улавливания паров бензина плохо продувается PO 442 EVAP CONTROL SMALL LEAK DETECTED Обнаружена небольшая утечка в системе улавливания паров PO 443 EVAP CONTROL PURGE CONT VALVE MALFUNC Управление клапаном продувки системы «EVAP» неисправен PO 444 EVAP PURGE VALVE CIRCUIT OPEN Клапан продувки системы «EVAP» всегда открыт PO 445 EVAP PURGE VALVE CIRCUIT SHORT Клапан продувки системы «EVAP» всегда закрыт PO 446 EVAP VENT CONTROL MALFUNCTION Управление воздушным клапаном системы «EVAP» неисправно PO 447 EVAP VENT CONTROL OPEN Воздушный клапан системы «EVAP» всегда открыт PO 448 EVAP VENT CONTROL SHORTED Воздушный клапан системы «EVAP» всегда закрыт PO 450 EVAP PRESS SENSOR MALFUNCTION Датчик давления паров бензина неисправен PO 451 EVAP CONTROL PRESS RANGE/PERFORMANCE Сигнал датчика давления паров бензина выходит за доп. диапазон PO 452 EVAP CONTROL PRESS SENSOR LOW INPUT Сигнал датчика давления паров бензина имеет низкий уровень PO 453 EVAP CONTROL PRESS SENSOR HIGH INPUT Сигнал датчика давления паров бензина имеет высокий уровень PO 454 EVAP CONTROL PRESS SENSOR INTERMITTENT Сигнал датчика давления паров бензина перемежающийся PO 455 EVAP CONTROL SYS GROSS LEAK DETECTED Обнаружена грубая утечка в системе улавливания паров PO 460 FUEL LEVEL SENSOR CIRCUIT MALFUNCTION Цепь датчика уровня топлива неисправна PO 461 FUEL LEVEL SENSOR RANGE/PERFORMANCE Сигнал датчика уровня топлива выходит за допустимые пределы PO 462 FUEL LEVEL SENSOR CIRCUIT LOW INPUT Сигнал датчика уровня топлива имеет низкий уровень PO 463 FUEL LEVEL SENSOR CIRCUIT HIGH INPUT Сигнал датчика уровня топлива имеет высокий уровень PO 464 FUEL LEVEL SENSOR CKT INTERMITTENT Сигнал датчика уровня топлива перемежающийся PO 465 PURGE FLOW SENSOR CIRCUIT MALFUNCTION Цепь датчика потока воздуха продувки неисправен PO 466 PURGE FLOW SENSOR RANGE/PERFORMANCE Сигнал датчика потока воздуха продувки выходит за доп. пределы PO 467 PURGE FLOW SENSOR CIRCUIT LOW INPUT Сигнал датчика потока воздуха продувки имеет низкий уровень PO 468 PURGE FLOW SENSOR CIRCUIT HIGH INPUT Сигнал датчика потока воздуха продувки имеет высокий уровень PO 469 PURGE FLOW SENSOR CKT INTERMITTENT Сигнал датчика потока воздуха продувки перемежающийся PO 470 EXHAUST PRESSURE SENSOR MALFUNCTION Датчик давления выхлопных газов неисправен PO 471 EXHAUST PRESSURE SENSOR RANGE/PERF Сигнал датчика давления выходит за доп. диапазон PO 472 EXHAUST PRESSURE SENSOR LOW Сигнал датчика давления имеет низкий уровень PO 473 EXHAUST PRESSURE SENSOR HIGH Сигнал датчика давления имеет высокий уровень PO 474 EXHAUST PRESSURE SENSOR INTERMIT Сигнал датчика давления перемежающийся PO 475 EXHAUST PRESS VALVE CONTROL MALFUNCTION Клапан датчика давления выхлопных газов неисправен PO 476 EXHAUST PRESS VALVE CONTROL RANGE/PERF Сигнал клапана датчика давления выходит за доп. диапазон PO 477 EXHAUST PRESS VALVE CONTROL LOW Сигнал клапана датчика давления имеет низкий уровень PO 478 EXHAUST PRESS VALVE CONTROL HIGH Сигнал клапана датчика давления имеет высокий уровень PO 479 EXHAUST PRESS VALVE CONTROL INTERMIT Сигнал клапана датчика давления перемежающийся PO 5XX VEHICLE SPEED, IDLE CONTROL AND AUXILIARY INPUTS PO 500 VSS SENSOR MALFUNCTION Датчик скорости автомобиля неисправен PO 501 VSS SENSOR RANGE/PERFORMANCE Сигнал датчика скорости автомобиля выходит за доп. пределы PO 502 VSS SENSOR CIRCUIT LOW INPUT Сигнал датчика скорости автомобиля имеет низкий уровень PO 503 VSS SENSOR INTERMIT/ERRATIC/HI Сигнал датчика перемежающийся или имеет высокий уровень PO 505 IDLE CONTROL SYSTEM MALFUNCTION Система поддержания холостого хода неисправна PO 506 IDLE CONTROL SYSTEM RPM TOO LOW Обороты двигателя под управлением системы слишком низкие PO 507 IDLE CONTROL SYSTEM RPM TOO HIGH Обороты двигателя под управлением системы слишком высокие PO 510 CLOSED TPS SWITCH MALFUNCTION Концевик индикации закрытого положения дросселя неисправен PO 530 A/C REFRIG PRESSURE SENSOR MALFUNCTION Датчик давления хладагента кондиционера неисправен PO 531 A/C REFRIG PRESSURE RANGE/PERFORMANCE Сигнал датчика давления хладагента выходит за доп. диапазон PO 532 A/C REFRIG PRESSURE SENSOR LOW INPUT Сигнал датчика давления хладагента имеет низкий уровень PO 533 A/C REFRIG PRESSURE SENSOR HIGH INPUT Сигнал датчика давления хладагента имеет высокий уровень PO 534 A/C REFRIGERANT CHARGE LOSS Большая потеря хладагента в кондиционере PO 550 PSP SENSOR CIRCUIT MALFUNCTION Датчик давления гидроусилителя руля неисправен PO 551 PSP SENSOR RANGE/PERFORMANCE Сигнал датчика давления выходит за допустимый диапазон PO 552 PSP SENSOR CIRCUIT LOW INPUT Сигнал датчика давления имеет низкий уровень PO 553 PSP SENSOR CIRCUIT HIGH INPUT Сигнал датчика давления имеет высокий уровень PO 554 PSP SENSOR CIRCUIT INTERMITTENT Сигнал датчика давления перемежающийся PO 560 SYSTEM VOLTAGE MALFUNCTION Датчик бортового напряжения неисправен PO 561 SYSTEM VOLTAGE UNSTABLE Бортовое напряжение нестабильно PO 562 SYSTEM VOLTAGE LOW Бортовое напряжение имеет низкий уровень PO 563 SYSTEM VOLTAGE HIGH Бортовое напряжение имеет высокий уровень PO 565 CRUISE CONTROL ON SIGNAL MALFUNCTION Цепь включения «круиз контроля» неисправна PO 566 CRUISE CONTROL OFF SIGNAL MALFUNCTION Цепь выключения «круиз контроля» неисправна PO 567 CRUISE CTRL RESUME SIGNAL MALFUNCTION Цепь продолжения работы «круиз контроля» неисправна PO 568 CRUISE CONTROL SET SIGNAL MALFUNCTION Цепь установки скорости «круиз контроля» неисправна PO 569 CRUISE CTRL COAST SIGNAL MALFUNCTION Цепь поддержки «наката» «круиз контроля» неисправна PO 570 CRUISE CTRL ACCEL SIGNAL MALFUNCTION Цепь поддержки «разгона» «круиз контроля» неисправна PO 571 CRUISE CTRL/BRK SW CKT A MALFUNCTION Переключатель включения тормозов «круиз контроля» неисправен PO 572 CRUISE CTRL/BRK SW CKT A LOW Переключатель всегда замкнут PO 573 CRUISE CTRL/BRK SW CKT A HIGH Переключатель всегда разомкнут PO 6XX COMPUTER AND AUXILIARY OUTPUTS PO 600 SERIAL COMM LINK MALFUNCTION Линия передачи последовательных данных неисправна PO 601 INTERNAL MEMORY CHECK SUM ERROR Ошибка контрольной суммы внутренней памяти PO 602 CONTROL MODULE PROGRAMMING ERROR Программная ошибка контрольного модуля PO 603 INTERN CONTROL MOD KAM ERROR Ошибка репрограммируемой памяти PO 604 INTERN CONTROL MOD RAM ERROR Ошибка оперативного запоминающего устройства PO 605 INTERN CONTROL MOD ROM ERROR Ошибка постоянного запоминающего устройства PO 606 PCM PROCESSOR FAULT Ошибка модуля управления энергосбережением PO 7XX TRANSMISSION PO 700 TRANS CONTROL SYS MALFUNCTION Система управления трансмиссией неисправна PO 701 TRANS CONTROL SYS RANGE/PERFORMANCE Система управления трансмиссией работает неверно PO 702 TRANS CONTROL SYSTEM ELECTRICAL PO 703 TORQ CONV/BRK SW B CKT MALFUNCTION Переключатель карданный вал/тормоза неисправен PO 704 CLUTCH SWITCH INPUT CIRCUIT MALFUNCTION Цепь датчика включения сцепления неисправен PO 705 TRANS RANGE SENSOR MALFUNCTION (PRNDL) Датчик диапазона работы трансмиссии неисправен PO 706 TRANS RANGE SENSOR RANGE/PERFORMANCE Сигнал датчика выходит за допустимые пределы PO 707 TRANS RANGE SENSOR CIRCUIT LOW INPUT Сигнал датчика имеет низкий уровень PO 708 TRANS RANGE SENSOR CIRCUIT HIGH INPUT имеет высокий уровень PO 709 TRANS RANGE SENSOR INTERMITTENT Сигнал датчика перемежающийся PO 710 TRANS FLUID TEMP SENSOR MALFUNCTION Датчик температуры трансмиссионной жидкости неисправен PO 711 TRANS FLUID TEMP RANGE/PERFRMANCE Сигнал датчика выходит за допустимые пределы PO 712 TRANS FLUID TEMP SENSOR LOW INPUT Сигнал датчика имеет низкий уровень PO 713 TRANS FLUID TEMP SENSOR HIGH INPUT имеет высокий уровень PO 714 TRANS FLUID TEMP CKT INTERMITTENT Сигнал датчика перемежающийся PO 715 INPUT/TURBINE SPEED SENSOR MALFUNCTION Датчик скорости турбины неисправен PO 716 INPUT/TURBINE SPEED RANGE/PERFORMANCE Сигнал датчика выходит за допустимые пределы PO 717 INPUT/TURBINE SPEED SENSOR NO SIGNAL Сигнал датчика отсутствует PO 718 INPUT/TURBINE SPEED SENSOR INTERMITTENT Сигнал датчика перемежающийся PO 719 TORQ CONV/BRK SW B CIRCUIT LOW Переключатель карданный вал/тормоза замкнут на массу PO 720 OUTPUT SPEED SENSOR CIRCUIT MALFUNCTION Цепь датчика «Внешней скорости» неисправна PO 721 OUTPUT SPEED SENSOR RANGE/PERFORMANCE Сигнал датчика «Внешней скорости» выходит за доп. пределы PO 722 OUTPUT SPEED SENSOR CIRCUIT NO SIGNAL Сигнал датчика «Внешней скорости» отсутствует PO 723 OUTPUT SPEED SENSOR CKT INTERMITTENT Сигнал датчика «Внешней скорости» перемежающийся PO 724 TORQ CONV/BRK SW B CIRCUIT HIGH Переключатель карданный вал/тормоза замкнут на питание PO 725 ENGINE SPEED SENSOR CIRCUIT MALFUNCTION Цепь датчика скорости вращения двигателя неисправен PO 726 ENGINE SPEED SENSOR RANGE/PERFORMANCE Сигнал датчика выходит за допустимые пределы PO 727 ENGINE SPEED SENSOR CIRCUIT NO SIGNAL Сигнал датчика отсутствует PO 728 ENGINE SPEED SENSOR CKT INTERMITTENT Сигнал датчика перемежающийся PO 730 GEAR RATIO INCORRECT Передаточное число трансмиссии неверно PO 731 GEAR 1 INCORRECT RATIO Передаточное число трансмиссии на 1 передаче неверно PO 732 GEAR 2 INCORRECT RATIO Передаточное число трансмиссии на 2 передаче неверно PO 733 GEAR 3 INCORRECT RATIO Передаточное число трансмиссии на 3 передаче неверно PO 734 GEAR 4 INCORRECT RATIO Передаточное число трансмиссии на 4 передаче неверно PO 735 GEAR 5 INCORRECT RATIO Передаточное число трансмиссии на 5 передаче неверно PO 736 REVERSE INCORRECT RATIO Передаточное число трансмиссии на передаче задн. хода неверно PO 740 TCC CIRCUIT MALFUNCTION Цепь управления блокировкой дифференциала неисправна PO 741 TCC PERF OR STUCK OFF Дифференциал всегда выключен (разблокирован) PO 742 TCC CIRCUIT STUCK ON Дифференциал всегда включен (заблокирован) PO 743 TCC CIRCUIT ELECTRICAL PO 744 TCC CIRCUIT INTERMITTENT Дифференциал состояние неустойчивое PO 745 PRESS CONTROL SOL MALFUNCTION Управление сжимающим соленоидом неисправно PO 746 PRESS CONT SOLENOID PERF OR STUCK OFF Соленоид всегда в выключенном состоянии PO 747 PRESSURE SOLENOID STUCK ON Соленоид всегда во включенном состоянии PO 748 PRESSURE CONTROL SOLENOID ELECTRICAL PO 749 PRESSURE CONTROL SOL INTERMITTENT Состояние соленоида неустойчиво PO 750 SHIFT SOLENOID A MALFUNCTION Соленоид «А» включения передачи неисправен PO 751 SHIFT SOLENOID A PERF OR STUCK OFF Соленоид «А» всегда в выключенном состоянии PO 752 SHIFT SOLENOID A STUCK ON Соленоид «А» всегда во включенном состоянии PO 753 SHIFT SOLENOID A ELECTRICAL PO 754 SHIFT SOLENOID A INTERMITTENT Состояние соленоида «А» неустойчиво PO 755 SHIFT SOLENOID B MALFUNCTION Соленоид «В» включения передачи неисправен PO 756 SHIFT SOLENOID B PERF OR STUCK OFF Соленоид «В» всегда в выключенном состоянии PO 757 SHIFT SOLENOID B STUCK ON Соленоид «В» всегда во включенном состоянии PO 758 SHIFT SOLENOID B ELECTRICAL PO 759 SHIFT SOLENOID B INTERMITTENT Состояние соленоида «В» неустойчиво PO 760 SHIFT SOLENOID C MALFUNCTION Соленоид «С» включения передачи неисправен PO 761 SHIFT SOLENOID C PERF OR STUCK OFF Соленоид «С» всегда в выключенном состоянии PO 762 SHIFT SOLENOID C STUCK ON Соленоид «С» всегда во включенном состоянии PO 763 SHIFT SOLENOID C ELECTRICAL PO 764 SHIFT SOLENOID C INTERMITTENT Состояние соленоида «С» неустойчиво PO 765 SHIFT SOLENOID D MALFUNCTION Соленоид «Д» включения передачи неисправен PO 766 SHIFT SOLENOID D PERF OR STUCK OFF Соленоид «Д» всегда в выключенном состоянии PO 767 SHIFT SOLENOID D STUCK ON Соленоид «Д» всегда во включенном состоянии PO 768 SHIFT SOLENOID D ELECTRICAL PO 769 SHIFT SOLENOID D INTERMITTENT Состояние соленоида «Д» неустойчиво PO 770 SHIFT SOLENOID E MALFUNCTION Соленоид «Е» включения передачи неисправен PO 771 SHIFT SOLENOID E PERF OR STUCK OFF Соленоид «Е» всегда в выключенном состоянии PO 772 SHIFT SOLENOID E STUCK ON Соленоид «Е» всегда во включенном состоянии PO 773 SHIFT SOLENOID E ELECTRICAL PO 774 SHIFT SOLENOID E INTERMITTENT Состояние соленоида «Е» неустойчиво PO 780 SHIFT MALFUNCTION Переключение передач не работает PO 781 1-2 SHIFT MALFUNCTION Переключение передач с 1-ой на 2-ю не работает PO 782 2-3 SHIFT MALFUNCTION Переключение передач со 2-й на 3-ю не работает PO 783 3-4 SHIFT MALFUNCTION Переключение передач с 3-й на 4-ю не работает PO 784 4-5 SHIFT MALFUNCTION Переключение передач с 4-й на 5-ю не работает PO 785 SHIFT/TIMING SOL MALFUNCTION Соленоид управления синхронизатором неисправен PO 786 SHIFT/TIMING SOL RANGE/PERFORMANCE PO 787 SHIFT/TIMING SOL LOW Соленоид управления синхронизатором всегда выключен PO 788 SHIFT/TIMING SOL HIGH Соленоид управления синхронизатором всегда включен PO 789 SHIFT/TIMING SOL INTERMITTENT Соленоид управления синхронизатором неустойчив PO 790 NORM/PERFORM SWITCH CIRCUIT MALFUNCTION Цепь переключателя режима движения неисправна P1 XX 1995 — Chrysler/Jeep P1 291 HEATED AIR INTAKE На впуске перегретый воздух P1 292 CN GAS HIGH PRESSURE Давление газа (бензина)где то в «CN» высокое P1 293 CN GAS LOW PRESSURE Давление газа (бензина)где то в «CN» низкое P1 294 IDLE SPEED PERFORMANCE Холостой ход нестабилен P1 295 TPS SENSOR NO 5V FEED На датчике положения дроссельной заслонки нет питания 5В P1 296 MAP SENSOR NO 5V FEED На датчике давления воздуха во впускном кол. нет питания 5В P1 297 MAP PNEUMATIC CHANGE Давление в датчике мало P1 298 WIDE OPEN THROTTLE LEAN Широко открытый дроссель беднит P1 298 NO VARIATION IN MAP SIGNAL IS DETECTED Обнаружено отсутствие изменений сигнала с P1 299 AIR FLOW TOO HIGH Поток воздуха слишком большой P1 390 CAM/CRANK TIMING Сбой по времени синхронизации коленчатого вала P1 391 CAM/CRANK SENSOR LOSS Пропадание сигнала датчика вращения коленчатого вала P1 391 NO PEAK PRI #1 WITH MAX DWELL TIME Отсутствие сигнала «начало отсчета» №1 больше пол. времени P1 392 NO PEAK PRI #2 WITH MAX DWELL TIME Отсутствие сигнала «начало отсчета» №2 больше пол. Времени P1 393 NO PEAK PRI #3 WITH MAX DWELL TIME Отсутствие сигнала «начало отсчета» №3 больше пол. Времени P1 394 NO PEAK PRI #4 WITH MAX DWELL TIME Отсутствие сигнала «начало отсчета» №4 больше пол. Времени P1 395 NO PEAK PRI #5 WITH MAX DWELL TIME Отсутствие сигнала «начало отсчета» №5 больше пол. времени P1 398 CRANK SENSOR Датчик положения коленчатого вала P1 399 WAIT TO STRT LMP CKT P1 486 EVAP HOSE PINCHED Пережат испарительный рукав P1 487 HI SPD FAN #2 CKT Цепь высокоскоростного вентилятора №2 P1 488 AUX 5 VOLT LOW OUTPUT Питание датчиков 5В отсутствует P1 489 HI SPD FAN RELAY CIRCUIT Цепь реле высокоскоростного вентилятора P1 490 LO SPD FAN RELAY CIRCUIT Цепь реле низкоскоростного вентилятора P1 491 RADIATOR FAN RELAY CIRCUIT Цепь реле радиаторного вентилятора P1 492 AMBIENT TEMP SENSOR HIGH Сигнал датчика внешней температуры всегда высокий P1 493 AMBIENT TEMP SENSOR LOW Сигнал датчика внешней температуры всегда низкий P1 494 LEAK DETECT PUMP PRESSURE SWITCH Обнаружена утечка в цепи переключателя давления насоса P1 495 LEAK DETECT PUMP SOLENOID CIRCUIT Обнаружена утечка в цепи соленоида насоса P1 496 5 VOLT LOW OUTPUT Отсутствует 5В выход P1 596 POWER STEEPING SW. BAD INPUT STATE Мощный шаговый переключатель имеет неправ. нач. положение P1 598 A/C PRESS SENSOR INPUT VOLT TOO LOW Сигнал датчика давления в кондиционере всегда низкий P1 599 A/C PRESS SENSOR INPUT VOLT TOO HIGH Сигнал датчика давления в кондиционере всегда высокий P1 698 NO COD MESGS RECVD TRANS CNTRL MOD Нет кодов сообщений принятых в «trans control mode» P1 699 NO CОD MESGS RECVD PWRTRAIN CNTRL MOD Нет кодов сообщений принятых в «powertrain control mode» P1 761 GOV CONTROL SYSTEM Управляющая контрольная система P1 762 GOV PRESS SENSOR OFFSET Сигнал датчика давления GOV смещен P1 763 GOV PRESS SENSOR HIGH Сигнал датчика давления GOV всегда высокий P1 764 GOV PRESS SENSOR LOW Сигнал датчика давления GOV всегда низкий P1 765 TRANS VOLTAGE RELAY CIRCUIT Изменение напряжения в цепи реле P1 899 PARK/NEUTRAL SWITCH WRONG INPUT STATE Переключатель парковки/нейтрали находится в ошибочном положении P1 XXX 1995—Ford P1 000 CHECK OF SYS INCOMP MORE DRIVING REQ’D P1 100 MAF SENSOR INTERMITTENT Сигнал датчика расхода воздуха перемежающийся P1 101 MAF SENSOR OUT OF RANGE Сигнал датчика расхода воздуха выходит из доп. диапазона P1 112 IAT SENSOR INTERMITTENT Сигнал датчика температуры воздуха на впуске перемежающийся P1 116 ECT SENSOR OUT OF RANGE Сигнал датчика температуры охл. жид. выходит из доп. диапазона P1 117 ECT SENSOR INTERMITTENT Сигнал датчика температуры охл. жид. Перемежающийся P1 120 TP CIRCUIT OUT OF RANGE LOW Сигнал датчика положения дросселя всегда низкий P1 121 TP SENSOR INCONSISTENT W/ MAF Сигнал датчика положения дросселя не согласуется с ДМРВ P1 124 TP SENSOR OUT OF RANGE Сигнал датчика положения дросселя выходит за доп. диапазон P1 125 TP SENSOR INTERMITTENT Сигнал датчика положения дросселя перемежающийся P1 130 H02 NO SWITCH B1 SI ADAPTIVE FUEL LIMIT P1 131 H02 NO SWITCH B1 SYNDICATES LEAN P1 132 H02 NO SWITCH B1 SYNDICATES RICH P1 150 H02 NO SWITCH B2 SI ADAPTIVE FUEL LIMIT P1 151 H02 NO SWITCH B2 SYNDICATES LEAN P1 152 H02 NO SWITCH B2 SYNDICATES RICH P1 220 SERIES THROTTLE CONTROL MALFUNCTION Последовательный канал управления дросселем неисправен P1 224 TPS B SELF TEST OUT OF RANGE Внутренний тест датчика положения дросселя выходит за доп. P1 233 FUEL PUMP DRIVER MODULE OFFLINE-MIL Драйвер модуля топливного насоса выключен и горит инд. лампа P1 234 FUEL PUMP DRIVER MODULE OFFLINE Драйвер модуля топливного насоса выключен P1 235 FUEL PUMP CONTROL OUT OF RANGE-MIL Драйвер модуля топливного насоса выходит из доп. диапазона P1 236 FUEL PUMP CONTROL OUT OF RANGE Драйвер модуля топливного насоса выходит из доп. диапазона P1 237 FUEL PUMP SECONDARY CIRCUIT MALF-MIL Вторичная цепь топливного насоса неисправна и горит инд. лампа P1 238 FUEL PUMP SECONDARY CIRCUIT MALFUNCTION Вторичная цепь топливного насоса неисправна P1 260- THEFT DETECTED ENGINE DISABLED Двигатель выключен противоугонной системой (обнаружен вор) P1 270 RPM OR VEH SPEED LIMITER REACHED Обороты двигателя или скорость авт. не достигают ограничителя P1 299 ENGINE OVERTEMP CONDITION Двигатель в состоянии перегрева P1 351 IGN DIAGNOSTIC INPUT MALFUNCTION Вход диагностики зажигания неисправен P1 352 IGN COIL A PRIMARY MALFUNCTION Первичная цепь катушки зажигания «А» неисправна P1 353 IGN COIL B PRIMARY MALFUNCTION Первичная цепь катушки зажигания «В» неисправна P1 354 IGN COIL C PRIMARY MALFUNCTION Первичная цепь катушки зажигания «С» неисправна P1 355 IGN COIL D PRIMARY MALFUNCTION Первичная цепь катушки зажигания «Д» неисправна P1 356 PIP WHILE IDM PULSE SAYS ENG NOT TURNIN Импульсы с зубчатого колеса говорят что двигатель не проворач. P1 357 IDM PULSE WIDTH NOT DEFINED Ширина «IDM» импульса не определяется P1 358 IDM SIGNAL OUT OF RANGE Ширина «IDM» импульса выходит из допустимого диапазона P1 359 SPARK OUTPUT CKT MALFUNCTION Выходная цепь зажигания неисправна P1 364 IGN COIL PRIMARY MALFUNCTION Первичная катушка зажигания неисправна P1 390 OCTANE ADJUST PIN IN USE/CIRCUIT OPEN Вывод октан потенциометра или его цепь оборваны P1 400 DPFE SENSOR LOW VOLTAGE Сигнал датчика «DPFE» всегда в низком уровне P1 401 DPFE SENSOR HIGH VOLTAGE Сигнал датчика «DPFE» всегда в высоким уровне P1 403 DPFE SENSOR HOSES REVERSED Сигнал датчика «DPFE» в шланге перевернут P1 405 DPFE SENSOR UPSTREAM HOSE OFF Сигнал датчика «DPFE» в обратном шланге не работает P1 406 DPFE SENSOR DOWNSTREAM HOSE OFF Сигнал датчика «DPFE» в прямом шланге не работает P1 407 EGR NO FLOW DETECTED Не обнаружен поток отработанных газов в системе рециркуляции P1 408 EGR FLOW OUT OF TEST RANGE Поток рециркуляции отработанных газов выходит из тестового диапазона P1 409 EGR CONTROL CIRCUIT MALFUNCTION Цепь управления рециркуляцией отработанных газов неисправна P1 413 SECONDARY AIR INJ CIRCUIT LOW VOLTAGE Цепь впрыска вторичного воздуха в низком уровне P1 414 SECONDARY AIR INJ CIRCUIT Hi VOLTAGE Цепь впрыска вторичного воздуха в высоком уровне P1 443 EVAP PURGE MALFUNCTION Продувка системы улавливания паров бензина неисправна P1 444 PURGE FLOW SENSOR CIRCUIT LOW INPUT Цепь датчика потока продувки адсорбера в низком уровне P1 445 PURGE FLOW SENSOR CIRCUIT HIGH INPUT Цепь датчика потока продувки адсорбера в высоком уровне P1 460 WIDE OPEN THROTTLE A/C CUTOUT FAILURE Кондиционер не выключается при полностью открытом дросселе P1 461 A/C PRESSURE CKT HIGH INPUT Цепь давления кондиционера всегда в высоком уровне P1 462 A/C PRESSURE CKT LOW INPUT Цепь давления кондиционера всегда в низком уровне P1 463 A/C PRESSURE INSUFFICIENT CHANGE Давление в кондиционере меняется недостаточно P1 464 A/C DEMAND OUT OF RANGE Запрос на включение кондиционера выходит из допустимого диапазона P1 469 A/C CYCLING PERIOD LOW Период повторения кондиционера мал P1 473 FAN MONITOR HIGH/W FANS OFF Управление вентилятором высокое а вентилятор выключен P1 474 FAN CONTROL LOW SPEED FAILURE Высокоскоростной контроль вентилятора неисправен P1 479 FAN CONTROL HIGH SPEED FAILURE Низкоскоростной контроль вентилятора неисправен P1 480 FAN MONITOR LOW/W LOW FAN ON Управление вентилятора низкое а вентилятор выключен P1 481 FAN MONITOR LOW/W HIGH FAN ON Управление вентилятора низкое а вентилятор выключен P1 500 VSS INTERMITTENT Сигнал датчика скорости автомобиля неисправен P1 505 IAC AT ADAPTIVE CLIP Ошибочная адаптация регулятора холостого хода P1 518 INLET MAN. RUNNER STUCK OPEN P1 519 INLET MAN. RUNNER STUCK CLOSED P1 520 INLET MAN. RUNNER MALFUNCTION P1 550 PSP OUT OF RANGE Давление в гидроусилителе руля выходит из допустимого диапазона P1 605 ROM/KAM TEST KEEP ALIVE MEM FAIL Тест заполнения ROM/KAM памяти показывает сбой P1 610 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 611 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 612 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 613 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 614 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 615 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 616 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 617 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 618 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 619 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 620 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 650 PSP SENSOR OUT OF RANGE Датчик гидроусилителя руля выходит из допустимого диапазона P1 651 PSP SENSOR INPUT MALFUNCTION Датчик гидроусилителя руля неисправен P1 701 REVERSE ENGAGEMENT ERROR Ошибка зацепления реверса P1 703 BRAKE SWITCH OUT OF RANGE Переключатель тормозов выходит за диапазон P1 705 TRANS RANGE SENSOR OUT OF RANGE Датчик выбора режима трансмиссии выходит за диапазон P1 709 PNP SWITCH OUT OF RANGE Переключатель парковка/нейтраль выходит за диапазон P1 711 TFT SENSOR OUT OF RANGE «TFT» датчик выходит за диапазон P1 729 4X4L SWITCH ERROR Переключатель 4Х4 неисправен P1 730 4X4 LOW ERROR 4Х4 ошибка низкого уровня P1 731 1-2 SHIFT ERROR Ошибка переключателя с 1ой на 2ю передачу P1 732 2-3 SHIFT ERROR Ошибка переключателя с 2ой на 3ю передачу P1 733 3-4 SHIFT ERROR Ошибка переключателя с 3ей на 4ю передачу P1 741 TCC CONTROL ERROR Ошибка управления сцеплением P1 742 TCC PWM SOL FAILED ON Соленоид включения сцепления не включается P1 743 TCC PWM SOL FAILED ON Соленоид включения сцепления не включается P1 744 TCC SYSTEM PERFORMANCE Медленная работа сцепления P1 746 EPC SOLENOID OPEN CIRCUIT Цепь «EPC» соленоида оборвана P1 747 EPC SOLENOID SHORT CIRCUIT Цепь «EPC» соленоида замкнута P1 749 EPC SOLENOID FAILED LOW «EPC» соленоид не задвигается P1 751 SHIFT SOLENOID A PERFORMANCE Соленоид «А» переключения передач медленно работает P1 754 COAST CLUTCH CKT MALFUNCTION Цепь включения накатной муфты не работает P1 756 SHIFT SOLENOID B PERFORMANCE Соленоид «В» переключения передач медленно работает P1 761 SHIFT SOLENOID C PERFORMANCE Соленоид «С» переключения передач медленно работает P1 766 SHIFT SOLENOID D PERFORMANCE Соленоид «Д» переключения передач медленно работает P1 780 TCS OUT OF RANGE TCS вышел из диапазона P1 781 4X4L SWITCH OUT OF RANGE 4Х4L - переключатель вышел из диапазона P1 783 TRANSMISSION OVERTEMPERATURE Трансмиссия перегрета P1 784 TRANS 1ST & REV. MECHANICAL FAILURE Первая или задняя передачи механически неисправна P1 785 TRANS 1ST & 2ND MECHANICAL FAILURE Первая или вторая передачи механически неисправна P1 788 VFS #2 OPEN CIRCUIT Цепь VFS №2 оборвана P1 789 VFS #2 SHORT CIRCUIT Цепь VFS №2 замкнута U1 39 VSS FAILURE Датчик скорости автомобиля неисправен U1 51 BRAKE SWITCH SIG. FAILURE Выключатель стоп-сигнала неисправен U1 135 IGN SWITCH SIG. FAILURE Выключатель (замок) зажигания неисправен U1 451 PATS MODULE NO RESP/ENG DISABLE Часть модулей не отвечает или двигатель выключен P1 XXX 1995—GM P1 2 BRAKE BOOSTER VAC SHORTED Вакуумный усилитель тормозов заткнут P1 3 BRAKE BOOSTER VAC OPEN Вакуумный усилитель тормозов открыт P1 5 BRAKE BOOSTER VAC TO LOW Вакуумный усилитель тормозов имеет низкий уровень вакуума P1 7 PCM DATA LINK PROBLEM Проблема с передачей данных из блока управления P1 37 ABS/TCS LOSS OF DATA Блок управления АБС или трансмиссии теряют данные P1 106 MAP INTERM. HIGH IN Датчик давления впускного воздуха перемежающийся высокий уровень P1 107 MAP INTERM. LOW IN Датчик давления впускного воздуха перемежающийся низкий уровень P1 111 INTAKE AIR TEMP INTERM. HIGH INPUT Датчик температуры впускного воздуха перемежающийся высокий уровень P1 112 IAT SENSOR INTERM. LOW INPUT Датчик температуры впускного воздуха перемежающийся низкий уровень P1 114 ECT INTERM. LOW INPUT Датчик температуры охл. жидкости перемежающийся высокий уровень P1 115 ECT INTERM. HIGH INPUT Датчик температуры охл. жидкости перемежающийся низкий уровень P1 121 TPS INTERM. HIGH INPUT Датчик положения дросселя перемежающийся высокий уровень P1 122 TPS INTERM. LOW INPUT Датчик положения дросселя перемежающийся низкий уровень P1 133 ENGINE 02 B1 SI SWITCHING Датчик кислорода «В1» медленно переключатель P1 134 ENGINE 02 B1 SI RATIO Датчик кислорода «В1» имеет малый рейтинг переключений P1 135 ENGINE 02 B1 SI MEAN VOLTS Датчик кислорода «В1» имеет смещение середины сигнала P1 153 ENGINE 02 B2 SI SWITCHING Датчик кислорода «В2» медленно переключатель P1 154 ENGINE 02 B2 SI RATIO Датчик кислорода «В2» имеет малый рейтинг переключений P1 155 ENGINE 02 B2 SI MEAN VOLTS Датчик кислорода «В2» имеет смещение середины сигнала P1 257 SUPER CHARGER OVER BOOST Супер заряженный над форсаж P1 274 INJECTOR WIRING INCORRECT Провода впрыска под соединены не правильно P1 350 BYPASS LINE MONITOR Аварийная линия управления P1 361 EST NO TOGGLE AFT ENABLE «EST» не поворачивается после включения P1 374 CRANK LOW RES CORRELATE Относительно низкий уровень сигнала датчика коленчатого вала P1 381 ABS SYS ROUGH ROAD DETECT COMM FAIL Датчик неровной дороги системы АБС неисправен P1 406 LINEAR EGR PINTLE POSITION ERROR Линейность системы рециркуляции отработанных газов нарушена P1 441 EVAPORATIVE SYS OPEN PURGE FLOW Система улавливания паров бензина открыта продувочному потоку P1 442 PURGE SOLENOID VAC SWITCH MALFUNCTION Переключатель продувочного соленоида не работает P1 508 IDLE CONTROL SYS LOW Система поддержания холостого хода не открывается P1 509 IDLE CONTROL SYS HIGH Система поддержания холостого хода не закрывается P1 520 PN SWITCH CIRCUIT FAULT Цепь переключателя “PN” неисправна P1 554 CRUISE STEPPER MTR LINK FAULT Связь с шаговым мотором круизконтроля нарушена P1 571 TRACTION CNTRL PWM LINK FAULT Связь с антипробуксовочой системой нарушена P1 573 TRACTION CNTRL ABS LOST SERIAL DATA Связь с антиблокировочной системой нарушена P1 619 OIL CHANGE RESET CIRCUIT FAULT Цепь запроса смены масла неисправна P1 626 PASSKEY FUEL ENABLE LOST Ключ разрешения топливоподачи потерян P1 629 PASSKEY FREQUENCY INVALID Частота ключа неправильная P1 635 VSBA VOLTAGE CIRCUIT FAULT P1 639 VSBB VOLTAGE CIRCUIT FAULT P1 641 ODMA OUTPUT 1 CIRCUIT FAULT P1 642 ODMA OUTPUT 2 CIRCUIT FAULT P1 643 ODMA OUTPUT 3 CIRCUIT FAULT P1 644 ODMA OUTPUT 4 CIRCUIT FAULT P1 645 ODMA OUTPUT 5 CIRCUIT FAULT P1 646 ODMA OUTPUT 6 CIRCUIT FAULT P1 647 ODMA OUTPUT 7 CIRCUIT FAULT P1 651 ODMB OUTPUT 1 CIRCUIT FAULT P1 652 ODMB OUTPUT 2 CIRCUIT FAULT P1 653 ODMB OUTPUT 3 CIRCUIT FAULT P1 654 ODMB OUTPUT 4 CIRCUIT FAULT P1 655 ODMB OUTPUT 5 CIRCUIT FAULT P1 656 ODMB OUTPUT 6 CIRCUIT FAULT P1 657 ODMB OUTPUT 7 CIRCUIT FAULT P1 661 ODMC OUTPUT 1 CIRCUIT FAULT P1 662 ODMC OUTPUT 2 CIRCUIT FAULT P1 663 ODMC OUTPUT 3 CIRCUIT FAULT P1 664 ODMC OUTPUT 4 CIRCUIT FAULT P1 665 ODMC OUTPUT 5 CIRCUIT FAULT P1 666 ODMC OUTPUT 6 CIRCUIT FAULT P1 667 ODMC OUTPUT 7 CIRCUIT FAULT P1 671 ODMD OUTPUT 1 CIRCUIT FAULT P1 672 ODMD OUTPUT 2 CIRCUIT FAULT P1 673 ODMD OUTPUT 3 CIRCUIT FAULT P1 674 ODMD OUTPUT 4 CIRCUIT FAULT P1 675 ‘ ODMD OUTPUT 5 CIRCUIT FAULT P1 676 ODMD OUTPUT 6 CIRCUIT FAULT P1 677 ODMD OUTPUT 7 CIRCUIT FAULT P1 801 SELECT SWITCH PERFORM FAULT (HMD) Переключатель режима работы неисправен P1 810 PSS MANIFOLD MALFUNCTION “PSS” трубопровод неисправен P1 811 MAX ADAPT & LONG SHIFT (HMD) P1 812 TRANS (HMD) HOT Трансмиссия перегрета P1 814 TORQUE CONVERTER OVER STRESSED Сцепление перегружено (ударная нагрузка) P1 860 TCC PWM SOLENOID CIRCUIT (HMD) P1 864 TCC SOLENOID CIRCUIT (HMD) P1 870 TRANSM COMPONENT SUPPING (HMD) P1 871 GEAR RATIO UNDEFINED Передача не определена P1 886 3 TO 2 SOLENOID CIRCUIT MALFUNCTION Цепь соленоида переключения с 3-ей на 2-ю передачи неисправна P1 889 3RD CLUTCH SWITCH PRESS SWITCH (HMD) BO 100 DRIVER AIR BAG CIRCUIT MALFUNCTION Цепь надувной подушки безопасности водителя неисправна BO 101 DRIVER AIR BAG CIRCUIT RANGE/PERF Сигнал цепи надувной подушки выходит за доп. диапазон BO 102 DRIVER AIR BAG CIRCUIT LOW INPUT Сигнал цепи надувной подушки всегда в низком положении BO 103 DRIVER AIR BAG CIRCUIT HIGH INPUT Сигнал цепи надувной подушки всегда в высоком положении BO 105 PASSENGER AIR BAG CIRCUIT MALFUNCTION Цепь надувной подушки безопасности пассажира неисправна BO 106 PASSENGER AIR BAG CIRCUIT RANGE/PERF Сигнал цепи надувной подушки выходит за доп. диапазон BO 107 PASSENGER AIR BAG CIRCUIT LOW INPUT Сигнал цепи надувной подушки всегда в низком положении BO 108 PASSENGER AIR BAG CIRCUIT HIGH INPUT Сигнал цепи надувной подушки всегда в высоком положении BO 110 DRVR-SIDE AIR BAG CIRCUIT MALFUNCTION Цепь надувной боковой подушки без. водителя неисправна BO 111 DRVR-SIDE AIR BAG CIRCUIT RANGE/PERF Сигнал цепи надувной подушки выходит за доп. диапазон BO 112 DRVR-SIDE AIR BAG CIRCUIT LOW INPUT Сигнал цепи надувной подушки всегда в низком положении BO 113 DRVR-SIDE AIR BAG CIRCUIT HIGH INPUT Сигнал цепи надувной подушки всегда в высоком положении BO 115 PSNGR-SIDE AIR BAG CIRCUIT MALFUNCTION Цепь надувной боковой подушки без. пассажира неисправна BO 116 PSNGR-SIDE AIR BAG CIRCUIT RANGE/PERF Сигнал цепи надувной подушки выходит за доп. диапазон BO 117 PSNGR-SIDE AIR BAG CIRCUIT LOW INPUT Сигнал цепи надувной подушки всегда в низком положении BO 118 PSNGR-SIDE AIR BAG CIRCUIT HIGH INPUT Сигнал цепи надувной подушки всегда в высоком положении BO 120 SEATBELT #1 SW MON. CIRCUIT MALFUNCTION Защелка ремня безопасности №1 неисправен BO 121 SEATBELT #1 SW MON. CIRCUIT RANGE/PERF Защелка ремня безопасности №1 работает медленно BO 122 SEATBELT #1 SW MON. CIRCUIT LOW INPUT Защелка ремня безопасности №1 имеет низкий вход BO 123 SEATBELT #1 SW MON. CIRCUIT HIGH INPUT Защелка ремня безопасности №1 имеет высокий вход BO 125 SEATBELT #2 SW MON. CIRCUIT MALFUNCTION Защелка ремня безопасности №2 неисправен BO 126 SEATBELT #2 SW MON. CIRCUIT RANGE/PERF Защелка ремня безопасности №2 работает медленно BO 127 SEATBELT #2 SW MON. CIRCUIT LOW INPUT Защелка ремня безопасности №2 имеет низкий вход BO 128 SEATBELT #2 SW MON. CIRCUIT HIGH INPUT Защелка ремня безопасности №2 имеет высокий вход BO 130 SEATBELT #1 RETRACT CIRCUIT MALFUNCTION Механизм натяжения ремня безопасности №1 неисправен BO 131 SEATBELT #1 RETRACT CIRCUIT RANGE/PERF Механизм натяжения ремня безопасности №1 работает медленно BO 132 SEATBELT #1 RETRACT CIRCUIT LOW INPUT Механизм натяжения ремня безопасности №1 имеет низкий вход BO 133 SEATBELT #1 RETRACT CIRCUIT HIGH INPUT Механизм натяжения ремня безопасности №1 имеет высокий вход BO 135 SEATBELT #2 RETRACT CIRCUIT MALFUNCTION Механизм натяжения ремня безопасности №2 неисправен BO 136 SEATBELT #2 RETRACT CIRCUIT RANGE/PERF Механизм натяжения ремня безопасности №2 работает медленно BO 137 SEATBELT #2 RETRACT CIRCUIT LOW INPUT Механизм натяжения ремня безопасности №2 имеет низкий вход BO 138 SEATBELT #2 RETRACT CIRCUIT HIGH INPUT Механизм натяжения ремня безопасности №2 имеет высокий вход BO 300 COOLING FAN #1 CIRCUIT MALFUNCTION Цепь вентилятора охлаждения №1 не работает BO 301 COOLING FAN #1 CIRCUIT RANGE/PERF Цепь вентилятора охлаждения №1 работает медленно BO 302 COOLING FAN #1 CIRCUIT LOW INPUT Цепь вентилятора охлаждения №1 имеет низкий сигнал BO 303 COOLING FAN #1 CIRCUIT HIGH INPUT Цепь вентилятора охлаждения №1 имеет высокий сигнал BO 305 COOLING FAN #2 CIRCUIT MALFUNCTION Цепь вентилятора охлаждения №2 не работает BO 306 COOLING FAN #2 CIRCUIT RANGE/PERF Цепь вентилятора охлаждения №2 работает медленно BO 307 COOLING FAN #2 CIRCUIT LOW INPUT Цепь вентилятора охлаждения №2 имеет низкий сигнал BO 308 COOLING FAN #2 CIRCUIT HIGH INPUT Цепь вентилятора охлаждения №2 имеет высокий сигнал BO 310 A/C CLUTCH CIRCUIT MALFUNCTION Цепь включения кондиционера неисправна BO 311 A/C CLUTCH CIRCUIT RANGE/PERF Цепь включения кондиционера работает медленно BO 312 A/C CLUTCH CIRCUIT LOW INPUT Цепь включения кондиционера имеет низкий сигнал BO 313 A/C CLUTCH CIRCUIT HIGH INPUT Цепь включения кондиционера имеет высокий сигнал BO 315 A/C PRESSURE #1 CIRCUIT MALFUNCTION Цепь компрессора кондиционера №1 неисправна BO 316 A/C PRESSURE #1 CIRCUIT RANGE/PERF Цепь компрессора кондиционера №1 работает медленно BO 317 A/C PRESSURE #1 CIRCUIT LOW INPUT Цепь компрессора кондиционера №1 имеет низкий сигнал B0 318 A/C PRESSURE #1 CIRCUIT HIGH INPUT Цепь компрессора кондиционера №1 имеет высокий сигнал B0 320 A/C PRESSURE #2 CIRCUIT MALFUNCTION Цепь компрессора кондиционера №2 неисправна B0 321 A/C PRESSURE #2 CIRCUIT RANGE/PERF Цепь компрессора кондиционера №2 работает медленно B0 322 A/C PRESSURE #2 CIRCUIT LOW INPUT Цепь компрессора кондиционера №2 имеет низкий сигнал B0 323 A/C PRESSURE #2 CIRCUIT HIGH INPUT Цепь компрессора кондиционера №2 имеет высокий сигнал B0 325 A/C PRESS REF (SIG) CIRCUIT MALFUNCTION B0 326 A/C PRESS REF (SIG) CIRCUIT RANGE/PERF B0 327 A/C PRESS REF (SIG) CIRCUIT LOW INPUT B0 328 A/C PRESS REF (SIG) CIRCUIT HIGH INPUT B0 330 OUTSIDE AIR TEMP CIRCUIT MALFUNCTION Цепь датчика температуры внешнего воздуха неисправна B0 331 OUTSIDE AIR TEMP CIRCUIT RANGE/PERF Цепь датчика температуры работает медленно B0 332 OUTSIDE AIR TEMP CIRCUIT LOW INPUT Цепь датчика температуры имеет низкий сигнал B0 333 OUTSIDE AIR TEMP CIRCUIT HIGH INPUT Цепь датчика температуры имеет высокий сигнал B0 335 IN AIR TEMP SENS #1 CIRCUIT MALFUNCTION Цепь датчика температуры внутреннего воздуха №1 неисправ. B0 336 IN AIR TEMP SENS #1 CIRCUIT RANGE/PERF Цепь датчика температуры №1 работает медленно B0 337 IN AIR TEMP SENS #1 CIRCUIT LOW INPUT Цепь датчика температуры №1 имеет низкий сигнал B0 338 IN AIR TEMP SENS #1 CIRCUIT HIGH INPUT Цепь датчика температуры №1 имеет высокий сигнал B0 340 IN AIR TEMP SENS #2 CIRCUIT MALFUNCTION Цепь датчика температуры внутреннего воздуха №2 неисправ. B0 341 IN AIR TEMP SENS #2 CIRCUIT RANGE/PERF Цепь датчика температуры №2 работает медленно B0 342 IN AIR TEMP SENS #2 CIRCUIT LOW INPUT Цепь датчика температуры №2 имеет низкий сигнал B0 343 IN AIR TEMP SENS #2 CIRCUIT HIGH INPUT Цепь датчика температуры №2 имеет высокий сигнал B0 345 SOLAR LOAD SENSOR 1 CIRCUIT MALFUNCTION Цепь датчика освещенности (солнечных батарей) №1 неиспр. B0 346 SOLAR LOAD SENSOR 1 CIRCUIT RANGE/PERF Цепь датчика освещенности №1 работает медленно B0 347 SOLAR LOAD SENSOR 1 CIRCUIT LOW INPUT Цепь датчика освещенности №1 имеет низкий сигнал B0 348 SOLAR LOAD SENSOR 1 CIRCUIT HIGH INPUT Цепь датчика освещенности №1 имеет высокий сигнал B0 350 SOLAR LOAD SENSOR 2 CIRCUIT MALFUNCTION Цепь датчика освещенности (солнечных батарей) №2 неиспр. B0 351 SOLAR LOAD SENSOR 2 CIRCUIT RANGE/PERF Цепь датчика освещенности №2 работает медленно B0 352 SOLAR LOAD SENSOR 2 CIRCUIT LOW INPUT Цепь датчика освещенности №2 имеет низкий сигнал B0 353 SOLAR LOAD SENSOR 2 CIRCUIT HIGH INPUT Цепь датчика освещенности №2 имеет высокий сигнал B0 355 BLOWER MTR #1 SPEED CIRCUIT MALFUNCTION Цепь управления скоростью вентилятора №1 неисправна B0 356 BLOWER MTR #1 SPEED CIRCUIT RANGE/PERF Цепь управления вентилятора №1 работает медленно B0 357 BLOWER MTR #1 SPEED CIRCUIT LOW INPUT Цепь управления вентилятора №1 имеет низкий сигнал B0 358 BLOWER MTR #1 SPEED CIRCUIT HIGH INPUT Цепь управления вентилятора №1 имеет высокий сигнал B0 360 BLOWER MTR #1 POWER CIRCUIT MALFUNCTION Цепь питания вентилятора №1 неисправна B0 361 BLOWER MTR #1 POWER CIRCUIT RANGE/PERF Цепь питания вентилятора №1 выходит за доп. диапазон B0 362 BLOWER MTR #1 POWER CIRCUIT LOW INPUT Цепь питания вентилятора №1 имеет низкий сигнал B0 363 BLOWER MTR #1 POWER CIRCUIT HIGH INPUT Цепь питания вентилятора №1 имеет высокий сигнал B0 365 BLOWER MTR #1 GND CIRCUIT MALFUNCTION Цепь заземления вентилятора №1 неисправна B0 366 BLOWER MTR #1 GND CIRCUIT RANGE/PERF Цепь заземления вентилятора №1 выходит за доп. диапазон B0 367 BLOWER MTR #1 GND CIRCUIT LOW INPUT Цепь заземления вентилятора №1 имеет низкий сигнал B0 368 BLOWER MTR #1 GND CIRCUIT HIGH INPUT Цепь заземления вентилятора №1 имеет высокий сигнал B0 370 A/C HIGH SIDE TEMP SENSOR MALFUNCTION Датчик температуры высшей точки кондиционера неисправен B0 371 A/C HIGH SIDE TEMP SENSOR RANGE/PERF Сигнал датчика температуры выходит за допустимый диапазон B0 372 A/C HIGH SIDE TEMP SENSOR LOW INPUT Сигнал датчика температуры имеет низкий уровень B0 373 A/C HIGH SIDE TEMP SENSOR HIGH INPUT Сигнал датчика температуры имеет высокий уровень B0 375 A/C EVAP INLET TEMP SENSOR MALFUNCTION Датчик температуры на входе вент. кондиц. неисправен B0 376 A/C EVAP INLET TEMP SENSOR RANGE/PERF Сигнал датчика температуры выходит за допустимый диапазон BO 377 A/C EVAP INLET TEMP SENSOR LOW INPUT Сигнал датчика температуры имеет низкий уровень BO 378 A/C EVAP INLET TEMP SENSOR HIGH INPUT Сигнал датчика температуры имеет высокий уровень BO 380 A/C REFRIGERANT UNDERPRESSURE Давление хладагента кондиционера недостаточно BO 381 A/C REFRIGERANT OVERPRESSURE Давление хладагента кондиционера избыточно BO 400 AIR FLOW CONTROL #1 DEFROST MALFUNCTION Упр. воздушным потоком размораживателя №1 неисправно BO 401 AIR FLOW CONTROL #1 DEFROST RANGE/PERF Упр. размораживателя №1 работает медленно BO 402 AIR FLOW CONTROL #1 DEFROST LOW INPUT Упр. размораживателя №1 имеет низкий сигнал BO 403 AIR FLOW CONTROL #1 DEFROST HIGH INPUT Упр. размораживателя №1 имеет высокий сигнал BO 405 AIR FLOW CONTROL #2 HEATER MALFUNCTION Упр. воздушным потоком нагревателя №2 неисправно BO 406 AIR FLOW CONTROL #2 HEATER RANGE/PERF Упр. нагревателя №2 работает медленно BO 407 AIR FLOW CONTROL #2 HEATER LOW INPUT Упр. нагревателя №2 имеет низкий сигнал BO 408 AIR FLOW CONTROL #2 HEATER HIGH INPUT Упр. нагревателя №2 имеет высокий сигнал BO 410 AIR FLOW CONTROL #3 BLEND MALFUNCTION Упр. воздушным потоком смесителя №3 неисправно BO 411 AIR FLOW CONTROL #3 BLEND RANGE/PERF Упр. смесителя №3 работает медленно BO 412 AIR FLOW CONTROL #3 BLEND LOW INPUT Упр. смесителя №3 имеет низкий сигнал BO 413 AIR FLOW CONTROL #3 BLEND HIGH INPUT Упр. смесителя №3 имеет высокий сигнал BO 415 AIR FLOW CONTROL #4 VENT MALFUNCTION Упр. воздушным потоком вентиляции №4 неисправно BO 416 AIR FLOW CONTROL #4 VENT RANGE/PERF Упр. вентиляции №4 работает медленно BO 417 AIR FLOW CONTROL #4 VENT LOW INPUT Упр. вентиляции №4 имеет низкий сигнал BO 418 AIR FLOW CONTROL #4 VENT HIGH INPUT Упр. вентиляции №4 имеет высокий сигнал BO 420 AIR FLOW CONTROL #5 A/C MALFUNCTION Упр. воздушным потоком кондиционирования №5 неисправно BO 421 AIR FLOW CONTROL #5 A/C RANGE/PERF Упр. кондиционирования №5 работает медленно BO 422 AIR FLOW CONTROL #5 A/C LOW INPUT Упр. кондиционирования №5 имеет низкий сигнал BO 423 AIR FLOW CONTROL #5 A/C HIGH INPUT Упр. кондиционирования №5 имеет высокий сигнал BO 425 AIR FLOW CONTROL #6 RECIRC MALFUNCTION Упр. воздушным потоком рециркуляции №6 неисправно BO 426 AIR FLOW CONTROL #6 RECIRC RANGE/PERF Упр. рециркуляции №6 работает медленно BO 427 AIR FLOW CONTROL #6 RECIRC LOW INPUT Упр. рециркуляции №6 имеет низкий сигнал BO 428 AIR FLOW CONTROL #6 RECIRC HIGH INPUT Упр. рециркуляции №6 имеет высокий сигнал BO 430 REAR DEFROST CIRCUIT MALFUNCTION Цепь размораживателя заднего стекла неисправна BO 431 REAR DEFROST CIRCUIT RANGE/PERF Цепь размораживателя заднего стекла работает медленно BO 432 REAR DEFROST CIRCUIT LOW INPUT Цепь размораживателя заднего стекла имеет низкий сигнал BO 433 REAR DEFROST CIRCUIT HIGH INPUT Цепь размораживателя заднего стекла имеет высокий сигнал BO 435 A/C REQUEST CIRCUIT MALFUNCTION Цепь запроса включения кондиционера неисправна BO 436 A/C REQUEST CIRCUIT RANGE/PERF Цепь запроса включения кондиционера работает медленно BO 437 A/C REQUEST CIRCUIT LOW INPUT Цепь запроса включения кондиционера имеет низкий сигнал BO 438 A/C REQUEST CIRCUIT HIGH INPUT Цепь запроса включения кондиционера BO 440 CONTROL HEAD #1 FEEDBACK MALFUNCTION BO 441 CONTROL HEAD #1 FEEDBACK RANGE/PERF BO 442 CONTROL HEAD #1 FEEDBACK LOW INPUT BO 443 CONTROL HEAD #1 FEEDBACK HIGH INPUT BO 445 CONTROL HEAD #FEEDBACK MALFUNCTION BO 446 CONTROL HEAD #FEEDBACK RANGE/PERF BO 447 CONTROL HEAD #2 FEEDBACK LOW INPUT BO 448 CONTROL HEAD #2 FEEDBACK HIGH INPUT BO 500 RH TURN SIGNAL CIRCUIT MALFUNCTION Цепь правого указателя поворота неисправна BO 501 RH TURN SIGNAL CIRCUIT RANGE/PERF Цепь правого указателя поворота работает медленно BO 502 RH TURN SIGNAL CIRCUIT LOW INPUT Цепь правого указателя поворота имеет низкий сигнал BO 503 RH TURN SIGNAL CIRCUIT HIGH INPUT Цепь правого указателя поворота имеет высокий сигнал BO 505 LH TURN SIGNAL CIRCUIT MALFUNCTION Цепь левого указателя поворота неисправна BO 506 LH TURN SIGNAL CIRCUIT RANGE/PERF Цепь левого указателя поворота работает медленно BO 507 LH TURN SIGNAL CIRCUIT LOW INPUT Цепь левого указателя поворота имеет низкий сигнал BO 508 LH TURN SIGNAL CIRCUIT HIGH INPUT Цепь левого указателя поворота имеет высокий сигнал BO 510 HEADLAMP INDICATORS CIRCUIT MALFUNCTION Цепь индикатора головного освещения неисправна BO 511 HEADLAMP INDICATORS CIRCUIT RANGE/PERF Цепь индикатора головного освещения работает медленно BO 512 HEADLAMP INDICATORS CIRCUIT LOW INPUT Цепь индикатора головного освещения имеет низкий сигнал BO 513 HEADLAMP INDICATORS CIRCUIT HIGH INPUT Цепь индикатора головного освещения имеет высокий сигнал BO 515 SPEEDOMETER CIRCUIT MALFUNCTION Цепь спидометра неисправна BO 516 SPEEDOMETER CIRCUIT RANGE/PERF Цепь спидометра работает медленно BO 517 SPEEDOMETER CIRCUIT LOW INPUT Цепь спидометра имеет низкий сигнал BO 518 SPEEDOMETER CIRCUIT HIGH INPUT Цепь спидометра имеет высокий сигнал BO 520 TACHOMETER CIRCUIT MALFUNCTION Цепь тахометра неисправна BO 521 TACHOMETER CIRCUIT RANGE/PERF Цепь тахометра работает медленно BO 522 TACHOMETER CIRCUIT LOW INPUT Цепь тахометра имеет низкий сигнал BO 523 TACHOMETER CIRCUIT HIGH INPUT Цепь тахометра имеет высокий сигнал BO 525 TEMPERATURE GAUGES CIRCUIT MALFUNCTION Цепь измерителей температуры неисправна BO 526 TEMPERATURE GAUGES CIRCUIT RANGE/PERF Цепь измерителей температуры работает медленно BO 527 TEMPERATURE GAUGES CIRCUIT LOW INPUT Цепь измерителей температуры имеет низкий сигнал BO 528 TEMPERATURE GAUGES CIRCUIT HIGH INPUT Цепь измерителей температуры имеет высокий сигнал BO 530 FUEL LEVEL GAUGE CIRCUIT MALFUNCTION Цепь измерителя уровня топлива неисправна BO 531 FUEL LEVEL GAUGE CIRCUIT RANGE/PERF Цепь измерителя уровня топлива работает медленно BO 532 FUEL LEVEL GAUGE CIRCUIT LOW INPUT Цепь измерителя уровня топлива имеет низкий сигнал BO 533 FUEL LEVEL GAUGE CIRCUIT HIGH INPUT Цепь измерителя уровня топлива имеет высокий сигнал BO 535 TURBO/SUPER BOOST GAUGE MALFUNCTION Измеритель турбо/ супер наддува неисправен BO 536 TURBO/SUPER BOOST GAUGE RANGE/PERF Измеритель турбо/ супер наддува работает медленно BO 537 TURBO/SUPER BOOST GAUGE LOW INPUT Измеритель турбо/ супер наддува имеет низкий сигнал BO 538 TURBO/SUPER BOOST GAUGE HIGH INPUT Измеритель турбо/ супер наддува имеет высокий сигнал BO 540 FASTEN SEATBELT INDICATOR MALFUNCTION Индикатор защелкивания ремня безопасности неисправен BO 541 FASTEN SEATBELT INDICATOR RANGE/PERF Индикатор защелкивания ремня безопасности работает медленно BO 542 FASTEN SEATBELT INDICATOR LOW INPUT Индикатор защелкивания ремня безопасности имеет низкий сигнал BO 543 FASTEN SEATBELT INDICATOR HIGH INPUT Индикатор защелкивания ремня безопасности имеет выс. сигнал BO 545 DOOR AJAR #1 INDICATOR MALFUNCTION Индикатор приоткрытой двери №1 неисправен BO 546 DOOR AJAR #1 INDICATOR RANGE/PERF Индикатор приоткрытой двери №1 работает медленно BO 547 DOOR AJAR #1 INDICATOR LOW INPUT Индикатор приоткрытой двери №1 имеет низкий сигнал BO 548 DOOR AJAR #1 INDICATOR HIGH INPUT Индикатор приоткрытой двери №1 имеет высокий сигнал BO 550 DOOR AJAR #2 INDICATOR MALFUNCTION Индикатор приоткрытой двери №2 неисправен BO 551 DOOR AJAR #2 INDICATOR RANGE/PERF Индикатор приоткрытой двери №2 работает медленно BO 552 DOOR AJAR #2 INDICATOR LOW INPUT Индикатор приоткрытой двери №2 имеет низкий сигнал BO 553 DOOR AJAR #2 INDICATOR HIGH INPUT Индикатор приоткрытой двери №2 имеет высокий сигнал BO 555 BRAKE INDICATOR CIRCUIT MALFUNCTION Цепь индикатора торможения неисправна BO 556 BRAKE INDICATOR CIRCUIT RANGE/PERF Цепь индикатора торможения работает медленно BO 557 BRAKE INDICATOR CIRCUIT LOW INPUT Цепь индикатора торможения имеет низкий сигнал BO 558 BRAKE INDICATOR CIRCUIT HIGH INPUT Цепь индикатора торможения имеет высокий сигнал BO 560 AIR BAG LAMP #1 CIRCUIT MALFUNCTION Цепь лампы воздушной подушки №1 неисправна BO 561 AIR BAG LAMP #1 CIRCUIT RANGE/PERF Цепь лампы воздушной подушки №1 работает медленно BO 562 AIR BAG LAMP #1 CIRCUIT LOW INPUT Цепь лампы воздушной подушки №1 имеет низкий сигнал BO 563 AIR BAG LAMP #1 CIRCUIT HIGH INPUT Цепь лампы воздушной подушки №1 имеет высокий сигнал BO 565 SECURITY OP INFO CIRCUIT MALFUNCTION Цепь информации о секретных опциях неисправна BO 566 SECURITY OP INFO CIRCUIT RANGE/PERF Цепь информации о секретных опциях работает медленно BO 567 SECURITY OP INFO CIRCUIT LOW INPUT Цепь информации о секретных опциях имеет низкий сигнал BO 568 SECURITY OP INFO CIRCUIT HIGH INPUT Цепь информации о секретных опциях имеет высокий сигнал BO 600 OPTION CONFIG ERROR Конфигурация опций ошибочна BO 601 KAM RESET Сброс «КАМ» датчика BO 602 OSC WATCHDOG COP MALFUNCTION Генератор управляющий системой «WATCHDOG» неисправен BO 603 EEPROM WRITE ERROR Ошибка записи во FLASH-пзу BO 604 EEPROM CALIBRATION ERROR Ошибка ПЗУ калибровок BO 605 EEPROM CHECKSUM ERROR Ошибка контрольной суммы ПЗУ BO 606 RAM MALFUNCTION Оперативное запоминающее устройство неисправно BO 607 INTERNAL ERROR Внутренняя ошибка BO 608 INITIALIZATION ERROR Ошибка инициализации BO 800 DEVICE POWER #1 CIRCUIT MALFUNCTION Цепь блока питания №1 неисправна BO 801 DEVICE POWER #1 CIRCUIT RANGE/PERF Сигнал цепи блока питания №1 выходит за допустимые пределы BO 802 DEVICE POWER #1 CIRCUIT LOW INPUT Сигнал цепи блока питания №1 всегда низкого уровня BO 803 DEVICE POWER #1 CIRCUIT HIGH INPUT Сигнал цепи блока питания №1 всегда высокого уровня BO 805 DEVICE POWER #2 CIRCUIT MALFUNCTION Цепь блока питания №2 неисправна BO 806 DEVICE POWER #2 CIRCUIT RANGE/PERF Сигнал цепи блока питания №2 выходит за допустимые пределы BO 807 DEVICE POWER #2 CIRCUIT LOW INPUT Сигнал цепи блока питания №2 всегда низкого уровня BO 808 DEVICE POWER #2 CIRCUIT HIGH INPUT Сигнал цепи блока питания №2 всегда высокого уровня BO 810 DEVICE POWER #3 CIRCUIT MALFUNCTION Цепь блока питания №3 неисправна BO 811 DEVICE POWER #3 CIRCUIT RANGE/PERF Сигнал цепи блока питания №3 выходит за допустимые пределы BO 812 DEVICE POWER #3 CIRCUIT LOW INPUT Сигнал цепи блока питания №3 всегда низкого уровня BO 813 DEVICE POWER #3 CIRCUIT HIGH INPUT Сигнал цепи блока питания №3 всегда высокого уровня BO 815 DEVICE GROUND #1 CIRCUIT MALFUNCTION Цепь заземления устройств №1 неисправна BO 816 DEVICE GROUND #1 CIRCUIT RANGE/PERF Сигнал цепи заземления №1 выходит за допустимые пределы BO 817 DEVICE GROUND #1 CIRCUIT LOW INPUT Сигнал цепи заземления №1 всегда низкого уровня BO 818 DEVICE GROUND #1 CIRCUIT HIGH INPUT Сигнал цепи заземления №1 всегда высокого уровня BO 820 DEVICE GROUND #2 CIRCUIT MALFUNCTION Цепь заземления устройств №2 неисправна BO 821 DEVICE GROUND #2 CIRCUIT RANGE/PERF Сигнал цепи заземления №2 выходит за допустимые пределы BO 822 DEVICE GROUND #2 CIRCUIT LOW INPUT Сигнал цепи заземления №2 всегда низкого уровня BO 823 DEVICE GROUND #2 CIRCUIT HIGH INPUT Сигнал цепи заземления №2 всегда высокого уровня BO 825 DEVICE GROUND #3 CIRCUIT MALFUNCTION Цепь заземления устройств №3 неисправна BO 826 DEVICE GROUND #3 CIRCUIT RANGE/PERF Сигнал цепи заземления №3 выходит за допустимые пределы BO 827 DEVICE GROUND #3 CIRCUIT LOW INPUT Сигнал цепи заземления №3 всегда низкого уровня BO 828 DEVICE GROUND #3 CIRCUIT HIGH INPUT Сигнал цепи заземления №3 всегда высокого уровня BO 830 IGNITION 0 CIRCUIT MALFUNCTION Цепь зажигания 0 неисправна BO 831 IGNITION 0 CIRCUIT RANGE/PERF Цепь зажигания 0 работает медленно BO 832 IGNITION 0 CIRCUIT LOW INPUT Цепь зажигания 0 имеет низкий уровень BO 833 IGNITION 0 CIRCUIT HIGH INPUT Цепь зажигания 0 имеет высокий уровень BO 835 IGNITION 1 CIRCUIT MALFUNCTION Цепь зажигания 1 неисправна BO 836 IGNITION 1 CIRCUIT RANGE/PERF Цепь зажигания 1 работает медленно BO 837 IGNITION 1 CIRCUIT LOW INPUT Цепь зажигания 1 имеет низкий уровень BO 838 IGNITION 1 CIRCUIT HIGH INPUT Цепь зажигания 1 имеет высокий уровень BO 840 IGNITION 3 CIRCUIT MALFUNCTION Цепь зажигания 3 неисправна BO 841 IGNITION 3 CIRCUIT RANGE/PERF Цепь зажигания 3 работает медленно BO 842 IGNITION 3 CIRCUIT LOW INPUT Цепь зажигания 3 имеет низкий уровень BO 843 IGNITION 3 CIRCUIT HIGH Цепь зажигания 3 имеет высокий уровень BO 845 INPUT DEVICE 5 VOLT REF CIRCUIT MALFUNCTION 5-и вольтовый блок питания неисправен BO 846 DEVICE 5 VOLT REF CIRCUIT RANGE/PERF Сигнал 5- В. блока питания выходит из допустимого диапазона BO 847 DEVICE 5 VOLT REF CIRCUIT LOW INPUT Сигнал 5- В. блока питания всегда низкого уровня BO 848 DEVICE 5 VOLT REF CIRCUIT HIGH INPUT Сигнал 5- В. блока питания всегда высокого уровня BO 850 (CLEAN)BATTERY CIRCUIT MALFUNCTION (Чистая) Цепь аккумуляторной батареи неисправна BO 851 (CLEAN)BATTERY CIRCUIT RANGE/PERF (Чистая) Цепь аккумуляторной батареи работает плохо BO 852 (CLEAN)BATTERY CIRCUIT LOW INPUT (Чистая) Цепь аккумуляторной батареи имеет низкий уровень BO 853 (CLEAN)BATTERY CIRCUIT HIGH INPUT (Чистая) Цепь аккумуляторной батареи имеет высокий уровень BO 855 (DIRTY)BATTERY CIRCUIT MALFUNCTION (Грязная) Цепь аккумуляторной батареи неисправна BO 856 (DIRTY)BATTERY CIRCUIT RANGE/PERF (Грязная) Цепь аккумуляторной батареи работает плохо BO 857 (DIRTY)BATTERY CIRCUIT LOW INPUT (Грязная) Цепь аккумуляторной батареи имеет низкий уровень BO 858 (DIRTY)BATTERY CIRCUIT HIGH INPUT (Грязная) Цепь аккумуляторной батареи имеет высокий уровень BO 860 SYSTEM VOLTAGE HIGH Высокое напряжение питания системы BO 856 SYSTEM VOLTAGE LOW Низкое напряжение питания системы CO 200 RF WHEEL SPD SENS CIRCUIT MALFUNCTION Цепь датчика скорости правого переднего колеса неисправна CO 201 RF WHEEL SPD SENS CIRCUIT RANGE/PERF Цепь датчика правого переднего колеса работает плохо CO 202 RF WHEEL SPD SENS CIRCUIT LOW INPUT Цепь датчика правого переднего колеса всегда в низком уровне CO 203 RF WHEEL SPD SENS CIRCUIT HIGH INPUT Цепь датчика правого переднего колеса всегда в высок. уровне CO 205 LF WHEEL SPD SENS CIRCUIT MALFUNCTION Цепь датчика скорости левого переднего колеса неисправна CO 206 LF WHEEL SPD SENS CIRCUIT RANGE/PERF Цепь датчика левого переднего колеса работает плохо CO 207 LF WHEEL SPD SENS CIRCUIT LOW INPUT Цепь датчика левого переднего колеса всегда в низком уровне CO 208 LF WHEEL SPD SENS CIRCUIT HIGH INPUT Цепь датчика левого переднего колеса всегда в высок. уровне CO 210 RR WHEEL SPD SENS CIRCUIT MALFUNCTION Цепь датчика скорости правого заднего колеса неисправна CO 211 RR WHEEL SPD SENS CIRCUIT RANGE/PERF Цепь датчика правого заднего колеса работает плохо CO 212 RR WHEEL SPD SENS CIRCUIT LOW INPUT Цепь датчика правого заднего колеса всегда в низком уровне CO 213 RR WHEEL SPD SENS CIRCUIT HIGH INPUT Цепь датчика правого заднего колеса всегда в высок. уровне CO 215 LR WHEEL SPD SENS CIRCUIT MALFUNCTION Цепь датчика скорости левого заднего колеса неисправна CO 216 LR WHEEL SPD SENS CIRCUIT RANGE/PERF Цепь датчика левого заднего колеса работает плохо CO 217 LR WHEEL SPD SENS CIRCUIT LOW INPUT Цепь датчика левого заднего колеса всегда в низком уровне CO 218 LR WHEEL SPD SENS CIRCUIT HIGH INPUT Цепь датчика левого заднего колеса всегда в высок. уровне CO 220 REAR WHEEL SPD SENS CIRCUIT MALFUNCTION Цепь датчика скорости заднего колеса неисправна CO 221 REAR WHEEL SPD SENS CIRCUIT RANGE/PERF Цепь датчика заднего колеса работает плохо CO 222 REAR WHEEL SPD SENS CIRCUIT LOW INPUT Цепь датчика заднего колеса всегда в низком уровне CO 223 REAR WHEEL SPD SENS CIRCUIT HIGH INPUT Цепь датчика заднего колеса всегда в высок. уровне CO 225 WHEEL SPD SENS FREQUENCY ERROR Частота датчика скорости колеса ошибочна CO 226 RF ABS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 АБС прав. пер. колеса неисправна CO 227 RF ABS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 АБС прав. пер. колеса раб. медленно CO 228 RF ABS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 АБС прав.пер.колеса в низком уровне CO 229 RF ABS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 АБС прав.пер.колеса в высок. уровне CO 231 RF ABS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 АБС прав. пер. колеса неисправна CO 232 RF ABS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 АБС прав. пер. колеса раб. медленно CO 233 RF ABS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 АБС прав.пер.колеса в низком уровне CO 234 RF ABS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 АБС прав.пер.колеса в высок. уровне CO 236 LF ABS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 АБС лев. пер. колеса неисправна CO 237 LF ABS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 АБС лев. пер. колеса раб. медленно CO 238 LF ABS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 АБС лев.пер.колеса в низком уровне CO 239 LF ABS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 АБС лев.пер.колеса в высок. уровне CO 241 LF ABS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 АБС лев. пер. колеса неисправна CO 242 LF ABS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 АБС лев. пер. колеса раб. медленно CO 243 LF ABS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 АБС лев.пер.колеса в низком уровне CO 244 LF ABS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 АБС лев.пер.колеса в высок. уровне CO 246 RR ABS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 АБС прав. зад. колеса неисправна CO 247 RR ABS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 АБС прав. зад. колеса раб. медленно CO 248 RR ABS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 АБС прав.зад.колеса в низком уровне CO 249 RR ABS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 АБС прав.зад.колеса в высок. уровне CO 251 RR ABS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 АБС прав. зад. колеса неисправна CO 252 RR ABS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 АБС прав. зад. колеса раб. медленно CO 253 RR ABS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 АБС прав.зад.колеса в низком уровне CO 254 RR ABS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 АБС прав.зад. колеса в высок. уровне CO 256 LR ABS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 АБС лев. зад. колеса неисправна CO 257 LR ABS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 АБС лев. зад. колеса раб. медленно CO 258 LR ABS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 АБС лев.зад.колеса в низком уровне CO 259 LR ABS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 АБС лев.зад.колеса в высок. уровне CO 261 RR ABS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 АБС прав. зад. колеса неисправна CO 262 RR ABS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 АБС прав. зад. колеса раб. медленно CO 263 RR ABS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 АБС прав.зад.колеса в низком уровне CO 264 RR ABS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 АБС прав.зад. колеса в высок. уровне CO 266 PUMP MOTOR CIRCUIT MALFUNCTION Цепь двигателя насоса неисправна CO 267 PUMP MOTOR CIRCUIT RANGE/PERF Цепь двигателя насоса работает не правильно CO 268 PUMP MOTOR CIRCUIT LOW INPUT Цепь двигателя насоса всегда в низком уровне CO 269 PUMP MOTOR CIRCUIT HIGH INPUT Цепь двигателя насоса CO 271 PUMP MOTOR RELAY CIRCUIT MALFUNCTION Цепь реле двигателя насоса неисправна CO 272 PUMP MOTOR RELAY CIRCUIT RANGE/PERF Цепь реле двигателя насоса работает не правильно CO 273 PUMP MOTOR RELAY CIRCUIT LOW INPUT Цепь реле двигателя насоса всегда в низком уровне CO 274 PUMP MOTOR RELAY CIRCUIT HIGH INPUT Цепь реле двигателя насоса всегда высоком уровне CO 276 VALVE RELAY CIRCUIT MALFUNCTION Цепь реле клапана неисправна CO 277 VALVE RELAY CIRCUIT RANGE/PERF Цепь реле клапана работает не правильно CO 278 VALVE RELAY CIRCUIT LOW INPUT Цепь реле клапана всегда в низком уровне CO 279 VALVE RELAY CIRCUIT HIGH INPUT Цепь реле клапана всегда высоком уровне CO 300 RF TCS SOUMTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 “TCS” прав. пер. колеса неисправна CO 301 RF TCS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 «TCS» прав. пер. колеса раб. Медленно CO 302 RF TCS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 «TCS» прав.пер.колеса в низком уровне CO 303 RF TCS SOUMTR # CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 «TCS» прав.пер.колеса в высок. Уровне CO 305 RF TCS SOUMTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 «TCS» прав. пер. колеса неисправна CO 306 RF TCS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 «TCS» прав. пер. колеса раб. Медленно CO 307 RF TCS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 «TCS» прав.пер.колеса в низком уровне CO 308 RF TCS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 «TCS» прав.пер.колеса в высок. Уровне CO 310 LF TCS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 «TCS» лев. пер. колеса неисправна CO 311 LF TCS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 «TCS» лев. пер. колеса раб. медленно CO 312 LF TCS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 «TCS» лев.пер.колеса в низком уровне CO 313 LF TCS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 «TCS» лев.пер.колеса в высок. уровне CO 315 LF TCS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 «TCS» лев. пер. колеса неисправна CO 316 LF TCS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 «TCS» лев. пер. колеса раб. медленно CO 317 LF TCS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 «TCS» лев.пер.колеса в низком уровне CO 318 LF TCS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 «TCS» лев.пер.колеса в высок. уровне CO 320 RR TCS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 «TCS» прав. зад. колеса неисправна CO 321 RR TCS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 «TCS» прав. зад. колеса раб. медленно CO 322 RR TCS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 «TCS» прав.зад.колеса в низком уровне CO 323 RR TCS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 «TCS» прав.зад.колеса в высок. уровне CO 325 RR TCS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 «TCS» прав. зад. колеса неисправна CO 326 RR TCS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 «TCS» прав. зад. колеса раб. медленно CO 327 RR TCS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 «TCS» прав.зад.колеса в низком уровне CO 328 RR TCS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 «TCS» прав.зад. колеса в высок. уровне CO 330 LR TCS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 «TCS» лев. зад. колеса неисправна CO 331 LR TCS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 «TCS» лев. зад. колеса раб. медленно CO 332 LR TCS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 «TCS» лев.зад.колеса в низком уровне CO 333 LR TCS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 «TCS» лев.зад.колеса в высок. уровне CO 335 RR TCS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 «TCS» прав. зад. колеса неисправна CO 336 RR TCS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 «TCS» прав. зад. колеса раб. медленно CO 337 RR TCS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 «TCS» прав.зад.колеса в низком уровне CO 338 RR TCS SOUMTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 «TCS» прав.зад. колеса в высок. уровне CO 340 ABS/TCS BRAKE SW. CIRCUIT MALFUNCTION Цепь переключения систем «ABS»/ “TCS” неисправна CO 341 ABS/TCS BRAKE SW. CIRCUIT RANGE/PERF Цепь переключения систем «ABS»/ “TCS” работает медленно CO 342 ABS/TCS BRAKE SW. CIRCUIT LOW INPUT Цепь переключения систем «ABS»/ “TCS” в низком уровне CO 343 ABS/TCS BRAKE SW. CIRCUIT HIGH INPUT Цепь переключения систем «ABS»/ “TCS” в высоком уровне CO 345 LOW BRAKE FLUID CIRCUIT MALFUNCTION Цепь датчика низкого уровня тормозной жидкости неисправна CO 346 LOW BRAKE FLUID CIRCUIT RANGE/PERF Цепь датчика уровня тормозной жидкости работает не правильно CO 347 LOW BRAKE FLUID CIRCUIT LOW INPUT Цепь датчика уровня тормозной жидкости в низком уровне CO 348 LOW BRAKE FLUID CIRCUIT HIGH INPUT Цепь датчика уровня тормозной жидкости в высоком уровне CO 350 REAR SOL/MTR #1 CIRCUIT MALFUNCTION Цепь заднего соленоида/привода №1 неисправна CO 351 REAR SOL/MTR #1 CIRCUIT RANGE/PERF Цепь заднего соленоида/привода №1 работает не правильно CO 352 REAR SOL/MTR #1 CIRCUIT LOW INPUT Цепь заднего соленоида/привода №1 в низком уровне CO 353 REAR SOL/MTR #1 CIRCUIT HIGH INPUT Цепь заднего соленоида/привода №1 в высоком уровне CO 355 THROTTLE REDUCT MTR CIRCUIT MALFUNCTION Цепь мотора привода дросселя неисправна CO 356 THROTTLE REDUCT MTR CIRCUIT RANGE/PERF Цепь мотора привода дросселя работает не правильно CO 357 THROTTLE REDUCT MTR CIRCUIT LOW INPUT Цепь мотора привода дросселя в низком уровне CO 358 THROTTLE REDUCT MTR CIRCUIT HIGH INPUT Цепь мотора привода дросселя в высоком уровне CO 360 SYSTEM PRESSURE CIRCUIT MALFUNCTION Цепь систем измерения давления неисправна CO 361 SYSTEM PRESSURE CIRCUIT RANGE/PERF Цепь систем измерения давления работает не правильно CO 362 SYSTEM PRESSURE CIRCUIT LOW INPUT Цепь систем измерения давления в низком уровне CO 363 SYSTEM PRESSURE CIRCUIT HIGH INPUT Цепь систем измерения давления в высоком уровне CO 365 LATERAL ACCELEROMTR CIRCUIT MALFUNCTION Цепь измерителя бокового ускорения неисправна CO 366 LATERAL ACCELEROMTR CIRCUIT RANGE/PERF Цепь измерителя бокового ускорения работает не правильно CO 367 LATERAL ACCELEROMTR CIRCUIT LOW INPUT Цепь измерителя бокового ускорения в низком уровне CO 368 LATERAL ACCELEROMTR CIRCUIT HIGH INPUT Цепь измерителя бокового ускорения в высоком уровне CO 370 YAW RATE CIRCUIT MALFUNCTION Цепь датчика курсовой устойчивости неисправна CO 371 YAW RATE CIRCUIT RANGE/PERF Цепь датчика курсовой устойчивости работает не правильно CO 372 YAW RATE CIRCUIT LOW INPUT Цепь датчика курсовой устойчивости в низком уровне CO 373 YAW RATE CIRCUIT HIGH INPUT Цепь датчика курсовой устойчивости в высоком уровне CO 500 STEEPING SOLENOID CIRCUIT MALFUNCTION Цепь втягивающего соленоида (втягивающего реле) неисправна CO 501 STEEPING SOLENOID CIRCUIT RANGE/PERF Цепь втягивающего соленоида работает не правильно CO 502 STEEPING SOLENOID CIRCUIT LOW INPUT Цепь втягивающего соленоида в низком уровне CO 503 STEEPING SOLENOID CIRCUIT HIGH INPUT Цепь втягивающего соленоида в высоком уровне CO 505 STEEPING POSITION SENSOR MALFUNCTION CO 506 STEEPING POSITION SENSOR RANGE/PERF CO 507 STEEPING POSITION SENSOR LOW INPUT CO 508 STEEPING POSITION SENSOR HIGH INPUT CO 510 STEEPING CHANGE RATE SENSOR MALFUNCTION CO 511 STEEPING CHANGE RATE SENSOR RANGE/PERF CO 512 STEEPING CHANGE RATE SENSOR LOW INPUT CO 513 STEEPING CHANGE RATE SENSOR HIGH INPUT CO 700 LF SOLENOID CIRCUIT MALFUNCTION Цепь левого переднего соленоида неисправна CO 701 LF SOLENOID CIRCUIT RANGE/PERF Цепь левого переднего соленоида работает не правильно CO 702 LF SOLENOID CIRCUIT LOW INPUT Цепь левого переднего соленоида в низком уровне CO 703 LF SOLENOID CIRCUIT HIGH INPUT Цепь левого переднего соленоида в высоком уровне CO 705 RF SOLENOID CIRCUIT MALFUNCTION Цепь правого переднего соленоида неисправна CO 706 RF SOLENOID CIRCUIT RANGE/PERF Цепь правого переднего соленоида работает не правильно CO 707 RF SOLENOID CIRCUIT LOW INPUT Цепь правого переднего соленоида в низком уровне CO 708 RF SOLENOID CIRCUIT HIGH INPUT Цепь правого переднего соленоида в высоком уровне CO 710 LR SOLENOID CIRCUIT MALFUNCTION Цепь левого заднего соленоида неисправна CO 711 LR SOLENOID CIRCUIT RANGE/PERF Цепь левого заднего соленоида работает не правильно CO 712 LR SOLENOID CIRCUIT LOW INPUT Цепь левого заднего соленоида в низком уровне CO 713 LR SOLENOID CIRCUIT HIGH INPUT Цепь левого заднего соленоида в высоком уровне CO 715 RR SOLENOID CIRCUIT MALFUNCTION Цепь правого заднего соленоида неисправна CO 716 RR SOLENOID CIRCUIT RANGE/PERF Цепь правого заднего соленоида работает не правильно CO 717 RR SOLENOID CIRCUIT LOW INPUT Цепь правого заднего соленоида в низком уровне CO 718 RR SOLENOID CIRCUIT HIGH INPUT Цепь правого заднего соленоида в высоком уровне CO 720 LF ACCELEROMTR CIRCUIT MALFUNCTION Цепь левого переднего акселерометра неисправна CO 721 LF ACCELEROMTR CIRCUIT RANGE/PERF Цепь левого переднего акселерометра работает не правильно CO 722 LF ACCELEROMTR CIRCUIT LOW INPUT Цепь левого переднего акселерометра в низком уровне CO 723 LF ACCELEROMTR CIRCUIT HIGH INPUT Цепь левого переднего акселерометра в высоком уровне CO 725 RF ACCELEROMTR CIRCUIT MALFUNCTION Цепь правого переднего акселерометра неисправна CO 726 RF ACCELEROMTR CIRCUIT RANGE/PERF Цепь правого переднего акселерометра работает не правильно CO 727 RF ACCELEROMTR CIRCUIT LOW INPUT Цепь правого переднего акселерометра в низком уровне CO 728 RF ACCELEROMTR CIRCUIT HIGH INPUT Цепь правого переднего акселерометра в высоком уровне CO 730 LR ACCELEROMTR CIRCUIT MALFUNCTION Цепь левого заднего акселерометра неисправна CO 731 LR ACCELEROMTR CIRCUIT RANGE/PERF Цепь левого заднего акселерометра работает не правильно CO 732 LR ACCELEROMTR CIRCUIT LOW INPUT Цепь левого заднего акселерометра в низком уровне CO 733 LR ACCELEROMTR CIRCUIT HIGH INPUT Цепь левого заднего акселерометра в высоком уровне CO 735 RR ACCELEROMTR CIRCUIT MALFUNCTION Цепь правого заднего акселерометра неисправна CO 736 RR ACCELEROMTR CIRCUIT RANGE/PERF Цепь правого заднего акселерометра работает не правильно CO 737 RR ACCELEROMTR CIRCUIT LOW INPUT Цепь правого заднего акселерометра в низком уровне CO 738 RR ACCELEROMTR CIRCUIT HIGH INPUT Цепь правого заднего акселерометра в высоком уровне CO 740 LF POSITION SENSOR CIRCUIT MALFUNCTION Цепь левого переднего датчика положения неисправна CO 741 LF POSITION SENSOR CIRCUIT RANGE/PERF Цепь левого переднего датчика положения работает не правильно CO 742 LF POSITION SENSOR CIRCUIT LOW INPUT Цепь левого переднего датчика положения в низком уровне CO 743 LF POSITION SENSOR CIRCUIT HIGH INPUT Цепь левого переднего датчика положения в высоком уровне CO 745 RF POSITION SENSOR CIRCUIT MALFUNCTION Цепь правого переднего датчика положения неисправна CO 746 RF POSITION SENSOR CIRCUIT RANGE/PERF Цепь правого переднего датчика положения работает не правильно CO 747 RF POSITION SENSOR CIRCUIT LOW INPUT Цепь правого переднего датчика положения в низком уровне CO 748 RF POSITION SENSOR CIRCUIT HIGH INPUT Цепь правого переднего датчика положения в высоком уровне CO 750 LR POSITION SENSOR CIRCUIT MALFUNCTION Цепь левого заднего датчика положения неисправна CO 751 LR POSITION SENSOR CIRCUIT RANGE/PERF Цепь левого заднего датчика положения работает не правильно CO 752 LR POSITION SENSOR CIRCUIT LOW INPUT Цепь левого заднего датчика положения в низком уровне CO 753 LR POSITION SENSOR CIRCUIT HIGH INPUT Цепь левого заднего датчика положения в высоком уровне CO 755 RR POSITION SENSOR CIRCUIT MALFUNCTION Цепь правого заднего датчика положения неисправна CO 756 RR POSITION SENSOR CIRCUIT RANGE/PERF Цепь правого заднего датчика положения работает не правильно CO 757 RR POSITION SENSOR CIRCUIT LOW INPUT Цепь правого заднего датчика положения в низком уровне CO 758 RR POSITION SENSOR CIRCUIT HIGH INPUT Цепь правого заднего датчика положения в высоком уровне Расшифровка диагностических кодов протокола OBD-II Пятизначный код ошибки Первая позиция: P - is for powertrain codes B - is for body codes C - is for chassis codes Вторая позиция: 0 - общий для OBD-II код 1 - код производителя Третья позиция - тип неисправности: 1 - топливная система или воздухоподача 2 - топливная система или воздухоподача 3 - система зажигания 4 - вспомогательный контроль 5 - холостой ход 6 - ECU или его цепи 7 - трансмиссия 8 - трансмиссия Четвертая и пятая позиции - Порядковый номер ошибки КОД Описание ошибки P0100 Неисправность цепи датчика расхода воздуха P0101 Выход сигнала датчика расхода воздуха из допустимого диапазона P0102 Низкий уровень выходного сигнала датчика расхода воздуха P0103 Высокий уровень выходного сигнала датчика расхода воздуха P0105 Неисправность датчика давления воздуха P0106 Выход сигнала датчика давления воздуха из допустимого диапазона P0107 Низкий уровень выходного сигнала датчика давления воздуха P0108 Высокий уровень выходного сигнала датчика давления воздуха P0110 Неисправность датчика температуры всасываемого воздуха P0111 Выход сигнала датчика температуры всасываемого воздуха из допустимого диапазона P0112 Низкий уровень датчика температуры всасываемого воздуха P0113 Высокий уровень датчика температуры всасываемого воздуха P0115 Неисправность датчика температуры охлаждающей жидкости P0116 Выходсигнала датчика температуры охлаждающей жидкости из допустимого диапазона P0117 Низкий уровень датчика температуры охлаждающей жидкости P0118 Высокий уровень датчика температуры охлаждающей жидкости P0120 Неисправность датчика положения дроссельной заслонки "A" P0121 Выход сигнала датчика положения дроссельной заслонки "A" из допустимого диапазона P0122 Низкий уровень выходного сигнала датчика положения дроссельной заслонки "A" P0123 Высокий уровень выходного сигнала датчика положения дроссельной заслонки "A" P0125 Низкая температура охлаждающей жидкости для управления по замкнутому контуру P0130 Датчик кислорода 1 (банк 1) неисправен P0131 Низкий уровень сигнала датчика кислорода 1 (банк 1) P0132 Высокий уровень сигнала датчика кислорода 1 (банк 1) P0133 Медленный отклик датчика кислорода 1 (банк 1) на обогащение/обеднение P0134 Нет активности выходного сигнала датчика кислорода 1 (банк 1) P0135 Нагреватель датчика кислорода 1 (банк 1) неисправен P0136 Датчик кислорода 2 (банк 1) неисправен P0137 Низкий уровень выходного сигнала датчика кислорода 2 (банк 1) P0138 Высокий уровень выходного сигнала датчика кислорода 2 (банк 1) P0139 Медленный отклик датчика кислорода 2 (банк 1) на обогащение/обеднение P0140 Нет активности выходного сигнала датчика кислорода 2 (банк 1) P0141 Нагреватель датчика кислорода 2 (банк 1) неисправен P0142 Датчик кислорода 3 (банк 1) неисправен P0143 Низкий уровень выходного сигнала датчика кислорода 3 (банк 1) P0144 Высокий уровень выходного сигнала датчика кислорода 3 (банк 1) P0145 Медленный отклик датчика кислорода 3 (банк 1) на обогащение/обеднение P0146 Нет активности выходного сигнала датчика кислорода 3 (банк 1) P0147 Нагреватель датчика кислорода 3 (банк 1) неисправен P0150 Датчик кислорода 1 (банк 2) неисправен P0151 Низкий уровень сигнала датчика кислорода 1 (банк 2) P0152 Высокий уровень сигнала датчика кислорода 1 (банк 2) P0153 Медленный отклик датчика кислорода 1 (банк 2) на обогащение/обеднение P0154 Нет активности выходного сигнала датчика кислорода 1 (банк 2) P0155 Нагреватель датчика кислорода 1 (банк 2) неисправен P0156 Датчик кислорода 2 (банк 2) неисправен P0157 Низкий уровень выходного сигнала датчика кислорода 2 (банк 2) P0158 Высокий уровень выходного сигнала датчика кислорода 2 (банк 2) P0159 Медленный отклик датчика кислорода 2 (банк 2) на обогащение/обеднение P0160 Нет активности выходного сигнала датчика кислорода 2 (банк 2) P0161 Нагреватель датчика кислорода 2 (банк 2) неисправен P0162 Датчик кислорода 3 (банк 2) неисправен P0163 Низкий уровень выходного сигнала датчика кислорода 3 (банк 2) P0164 Высокий уровень выходного сигнала датчика кислорода 3 (банк 2) P0165 Медленный отклик датчика кислорода 3 (банк 2) на обогащение/обеднение P0166 Нет активности выходного сигнала датчика кислорода 3 (банк 2) P0167 Нагреватель датчика кислорода 3 (банк 2) неисправен P0171 Слишком бедная смесь (возможен подсос воздуха) P0172 Слишком богатая смесь P0173 Утечка топлива из топливной системы блока цилиндров №2 P0174 Смесь блока цилиндров №2 слишком бедная P0175 Смесь блока цилиндров №2 слишком богатая P0176 Датчик выброса СНх (Fuel Composition) неисправен P0177 Сигнал датчика СНх (Fuel Composition) вне допустимого диапазона P0178 Низкий уровень сигнала датчика СНх (Fuel Composition) P0179 Высокий уровень сигнала датчика СНх (Fuel Composition) P0180 Неисправность цепи датчика температуры топлива "А" P0181 Сигнал датчика температуры топлива "А" вне допустимого диапазона P0182 Низкий уровень сигнала датчика температуры топлива "А" P0183 Высокий уровень сигнала датчика температуры топлива "А" P0185 Неисправность цепи датчика температуры топлива "В" P0186 Сигнал датчика температуры топлива "В" вне допустимого диапазона P0187 Низкий уровень сигнала датчика температуры топлива "В" P0188 Высокий уровень сигнала датчика температуры топлива "В" P0190 Неисправность цепи датчика давления топлива в топливной рампе P0191 Сигнал датчика давления в топливной рампе вне допустимого диапазона P0192 Низкий сигнал датчика давления топлива в топливной рампе P0193 Высокий сигнал датчика давления топлива в топливной рампе P0194 Перемежающийся сигнал датчика давления топлива в топливной рампе P0195 Неисправность цепи датчика температуры масла в двигателе P0196 Сигнал датчика температуры масла в двигателе вне допустимого диапазона P0197 Низкий сигнал датчика температуры масла в двигателе P0198 Высокий сигнал датчика температуры масла в двигателе P0199 Перемежающийся сигнал датчика температуры масла в двигателе P0200 Неисправность цепи управления форсунками P0201 Неисправность цепи управления форсункой №1 P0202 Неисправность цепи управления форсункой №2 P0203 Неисправность цепи управления форсункой №3 P0204 Неисправность цепи управления форсункой №4 P0205 Неисправность цепи управления форсункой №5 P0206 Неисправность цепи управления форсункой №6 P0207 Неисправность цепи управления форсункой №7 P0208 Неисправность цепи управления форсункой №8 P0209 Неисправность цепи управления форсункой №9 P0210 Неисправность цепи управления форсункой №10 P0211 Неисправность цепи управления форсункой №11 P0212 Неисправность цепи управления форсункой №12 P0213 Неисправность цепи управления форсункой холодного старта №1 P0214 Неисправность цепи управления форсункой холодного старта №2 P0215 Неисправность соленоида выключения двигателя P0216 Неисправность цепи контроля времени впрыска P0217 Перегрев двигателя P0218 Перегрев трансмиссии P0219 Двигатель "перекручен" (Engine Overspeed Condition) P0220 Неисправность датчика положения дроссельной заслонки "B" P0221 Сигнал датчика положения дроссельной заслонки "B" вне допустимого диапазона P0222 Низкий уровень сигнала датчика положения дроссельной заслонки "B" P0223 Высокий уровень сигнала датчика положения дроссельной заслонки "B" P0224 Перемежающийся уровень сигнала датчика положения дроссельной заслонки "B" P0225 Неисправность датчика положения дроссельной заслонки "C" P0226 Сигнал датчика положения дроссельной заслонки вне допустимого диапазона "C" P0227 Низкий уровень сигнала датчика положения дроссельной заслонки "C" P0228 Высокий уровень сигнала датчика положения дроссельной заслонки "C" P0229 Перемежающийся уровень сигнала датчика положения дроссельной заслонки "C" P0230 Неисправность первичной цепи управления бензонасосом (упр. реле бензонасоса) P0231 Постоянный низкий уровень вторичной цепи бензонасоса P0232 Постоянный высокий уровень вторичной цепи бензонасоса P0233 Перемежающийся уровень вторичной цепи бензонасоса P0235 Неисправность цепи датчика давления турбонаддува "A" P0236 Сигнал с датчика турбины "A" вне допустимого диапазона P0237 Низкий уровень сигнала с датчика турбины "A" P0238 Высокий уровень сигнала с датчика турбины "A" P0239 Неисправность цепи датчика давления турбонаддува "B" P0240 Сигнал с датчика турбины "B" вне допустимого диапазона P0241 Низкий уровень сигнала с датчика турбины "B" P0242 Высокий уровень сигнала с датчика турбины "B" P0243 Неисправность соленоида затвора выхлопных газов турбины "A" P0244 Сигнал соленоида затвора выхлопных газов турбины "A" вне доп. диапазона P0245 Соленоид затвора выхлопных газов турбины "A" всегда открыт P0246 Соленоид затвора выхлопных газов турбины "A" всегда закрыт P0247 Неисправность соленоида затвора выхлопных газов турбины "B" P0248 Сигнал соленоида затвора выхлопных газов турбины "B" вне доп. диапазона P0249 Соленоид затвора выхлопных газов турбины "B" всегда открыт P0250 Соленоид затвора выхлопных газов турбины "B" всегда закрыт P0251 Неисправность насоса впрыска турбины"A" P0252 Сигнал насоса впрыска турбины "A" не допустимого диапазона P0253 Низкий уровень сигнала насоса впрыска турбины "A" P0254 Высокий уровень сигнала насоса впрыска турбины "A" P0255 Перемежающийся уровень сигнала насоса впрыска турбины "A" P0256 Неисправность насоса впрыска турбины "B" P0257 Сигнал насоса впрыска турбины "B" вне допустимого диапазона P0258 Низкий уровень сигнала насоса впрыска турбины "B" P0259 Высокий уровень сигнала насоса впрыска турбины "B" P0260 Перемежающийся уровень сигнала насоса впрыска турбины "B" P0261 Форсунка цилиндра №1 - замыкание на землю P0262 Форсунка цилиндра №1 - обрыв или замыкание на +12V P0263 Форсунка цилиндра №1 - неисправность драйвера форсунки P0264 Форсунка цилиндра №2 - замыкание на землю P0265 Форсунка цилиндра №2 - обрыв или замыкание на +12V P0266 Форсунка цилиндра №2 - неисправность драйвера форсунки P0267 Форсунка цилиндра №3 - замыкание на землю P0268 Форсунка цилиндра №3 - обрыв или замыкание на +12V P0269 Форсунка цилиндра №3 - неисправность драйвера форсунки P0270 Форсунка цилиндра №4 - замыкание на землю P0271 Форсунка цилиндра №4 - обрыв или замыкание на +12V P0272 Форсунка цилиндра №4 - неисправность драйвера форсунки P0273 Форсунка цилиндра №5 - замыкание на землю P0274 Форсунка цилиндра №5 - обрыв или замыкание на +12V P0275 Форсунка цилиндра №5 - неисправность драйвера форсунки P0276 Форсунка цилиндра №6 - замыкание на землю P0277 Форсунка цилиндра №6 - обрыв или замыкание на +12V P0278 Форсунка цилиндра №6 - неисправность драйвера форсунки P0279 Форсунка цилиндра №7 - замыкание на землю P0280 Форсунка цилиндра №7 - обрыв или замыкание на +12V P0281 Форсунка цилиндра №7 - неисправность драйвера форсунки P0282 Форсунка цилиндра №8 - замыкание на землю P0283 Форсунка цилиндра №8 - обрыв или замыкание на +12V P0284 Форсунка цилиндра №8 - неисправность драйвера форсунки P0285 Форсунка цилиндра №9 - замыкание на землю P0286 Форсунка цилиндра №9 - обрыв или замыкание на +12V P0287 Форсунка цилиндра №9 - неисправность драйвера форсунки P0288 Форсунка цилиндра №10 - замыкание на землю P0289 Форсунка цилиндра №10 - обрыв или замыкание на +12V P0290 Форсунка цилиндра №10 - неисправность драйвера форсунки P0291 Форсунка цилиндра №11 - замыкание на землю P0292 Форсунка цилиндра №11 - обрыв или замыкание на +12 P0293 Форсунка цилиндра №11 - неисправность драйвера форсунки P0294 Форсунка цилиндра №12 - замыкание на землю P0295 Форсунка цилиндра №12 - обрыв или замыкание на +12V P0296 Форсунка цилиндра №12 - неисправность драйвера форсунки P0300 Обнаружены случайные/множественные пропуски зажигания P0301 Обнаружены пропуски зажигания в цилиндре №1 P0302 Обнаружены пропуски зажигания в цилиндре №2 P0303 Обнаружены пропуски зажигания в цилиндре №3 P0304 Обнаружены пропуски зажигания в цилиндре №4 P0305 Обнаружены пропуски зажигания в цилиндре №5 P0306 Обнаружены пропуски зажигания в цилиндре №6 P0307 Обнаружены пропуски зажигания в цилиндре №7 P0308 Обнаружены пропуски зажигания в цилиндре №8 P0309 Обнаружены пропуски зажигания в цилиндре №9 P0310 Обнаружены пропуски зажигания в цилиндре №10 P0311 Обнаружены пропуски зажигания в цилиндре №11 P0312 Обнаружены пропуски зажигания в цилиндре №12 P0320 Неисправноcть цепи распределителя зажигания P0321 Сигнал распределителя зажигания вне допустимого диапазона P0322 Сигнал распределителя зажигания отсутствует P0323 Сигнал распределителя зажигания перемежающийся P0325 Неисправность цепи датчика детонации №1 P0326 Сигнал датчика детонации №1 вне допустимого диапазона P0327 Низкий уровень сигнала датчика детонации №1 P0328 Высокий уровень сигнала датчика детонации №1 P0329 Перемежающийся уровень сигнала датчика детонации №1 P0330 Неисправность цепи датчика детонации №2 P0331 Сигнал датчика детонации №2 вне допустимого диапазона P0332 Низкий уровень сигнала датчика детонации №2 P0333 Высокий уровень сигнала датчика детонации №2 P0334 Перемежающийся уровень сигнала датчика детонации №2 P0335 Ошибка датчика положения коленвала"A" P0336 Ошибка ДПКВ "A" (пропуск одного зуба) P0337 Низкий уровень или замыкание на массу ДПКВ "A" P0338 Высокий уровень или замыкание на +12V ДПКВ "A" P0339 Перемежающийся сигнал ДПКВ "A" P0340 Неисправность датчика распределительного вала P0341 Сигнал датчика распределительного вала вне допустимого диапазона P0342 Низкий уровень сигнала датчика распределительного вала P0343 Высокий уровень сигнала датчика распределительного вала P0344 Перемежающийся уровень сигнала датчика распределительного вала P0350 Неисправность первичной / вторичной цепи катушки зажигания P0351 Неисправность первичной / вторичной цепи катушки зажигания "A" P0352 Неисправность первичной / вторичной цепи катушки зажигания "B" P0353 Неисправность первичной / вторичной цепи катушки зажигания "C" P0354 Неисправность первичной / вторичной цепи катушки зажигания "D" P0355 Неисправность первичной / вторичной цепи катушки зажигания "E" P0356 Неисправность первичной / вторичной цепи катушки зажигания" F" P0357 Неисправность первичной / вторичной цепи катушки зажигания "G" P0358 Неисправность первичной / вторичной цепи катушки зажигания "H" P0359 Неисправность первичной / вторичной цепи катушки зажигания "I" P0360 Неисправность первичной / вторичной цепи катушки зажигания "J" P0361 Неисправность первичной / вторичной цепи катушки зажигания "K" P0362 Неисправность первичной / вторичной цепи катушки зажигания "L" P0370 TIMING REF (HRS) A MAILFUNCTION P0371 TIMING REF (HRS) A TOO MANY PULSES P0372 TIMING REF (HRS) A TOO MANY PULSES P0373 TIMING REF (HRS) A INTERMITTENT PULSES P0374 TIMING REF (HRS) A NO PULSES P0375 TIMING REF (HRS) B MAILFUNCTION P0376 TIMING REF (HRS) B TOO MANY PULSES P0377 TIMING REF (HRS) B TOO MANY PULSES P0378 TIMING REF (HRS) B INTERMITTENT PULSES P0379 TIMING REF (HRS) B NO PULSES P0380 Неисправность свечи накаливания или цепи нагрева P0381 Неисправность свечи накаливания или индикатора нагрева P0385 Неисправность цепи датчика положения коленвала "B" P0386 Сигнал датчика положения коленвала "B" вне допустимого диапазона P0387 Низкий уровень или замыкание на массу ДПКВ "В" P0388 Высокий уровень или замыкаение на +12V ДПКВ "В" P0389 Перемежающийся сигнал датчика положения коленвала "B" P0400 Неисправность системы рециркуляции отработанных газов P0401 Неэффективность системы рециркуляции отработанных газов P0402 Избыточность системы рециркуляции отработанных газов (ОГ) P0403 Неисправность цепи датчика системы рециркуляции отработанных газов P0404 Сигнал датчика системы рециркуляции ОГ вне допустимого диапазона P0405 Низкий уровень сигнала датчика "A" системы рециркуляции ОГ P0406 Высокий уровень сигнала датчика "A" системы рециркуляции ОГ P0407 Низкий уровень сигнала датчика "В" системы рециркуляции ОГ P0408 Высокий уровень сигнала датчика "В" системы рециркуляции ОГ P0410 Неисправность системы вторичной подачи воздуха P0411 Некорректный поток через систему вторичной подачи воздуха P0412 Неисправность клапана системы вторичной подачи воздуха"A" P0413 Клапан системы вторичной подачи воздуха "A" всегда открыт P0414 Клапан системы вторичной подачи воздуха "A" всегда закрыт P0415 Неисправность клапана системы вторичной подачи воздуха "В" P0416 Клапан системы вторичной подачи воздуха "В" всегда открыт P0417 Клапан системы вторичной подачи воздуха "В" всегда закрыт P0420 Эффективность системы катализаторов В1 ниже допустимого порога P0421 Эффективность прогрева катализаторов В1 ниже допустимого порога P0422 Эффективность главного катализатора В1 ниже допустимого порога P0423 Эффективность нагревателя катализатора В1 ниже допустимого порога P0424 Температура нагревателя катализатора В1 ниже допустимого порога P0430 Эффективность системы катализаторов В2 ниже допустимого порога P0431 Эффективность прогрева катализаторов В3 ниже допустимого порога P0432 Эффективность главного катализатора В2 ниже допустимого порога P0433 Эффективность нагревателя катализатора В2 ниже допустимого порога P0434 Температура нагревателя катализатора В2 ниже допустимого порога P0440 Неисправность контроля системы улавливания паров бензина P0441 Плохая продувка системы улавливания паров бензина P0442 Небольшая утечка в системе улавливания паров бензина P0443 Неисправность цепи клапана продувки системы улавливания паров бензина P0444 Клапан продувки системы улавливания паров бензина всегда открыт P0445 Клапан продувки системы улавливания паров бензина всегда закрыт P0446 Неисправность упр. воздушным клапаном системы улавливания паров P0447 Воздушный клапан системы улавливания паров всегда открыт P0448 Воздушный клапан системы улавливания паров всегда закрыт P0450 Неисправность датчика давления паров бензина P0451 Сигнал датчика давления паров бензина вне допустимого диапазона P0452 Низкий уровень сигнал датчика давления паров бензина P0453 Высокий уровень сигнал датчика давления паров бензина P0454 Перемежающийся уровень сигнал датчика давления паров бензина P0455 Большая утечка в системе улавливания паров бензина P0460 Неисправность цепи датчика уровня топлива P0461 Сигнал датчика уровня топлива вне допустимого диапазона P0462 Низкий уровень сигнала датчика уровня топлива P0463 Высокий уровень сигнала датчика уровня топлива P0464 Перемежающийся уровень сигнала датчика уровня топлива P0465 Неисправность цепи датчика потока воздуха продувки P0466 Сигнал датчика потока воздуха продувки вне допустимого диапазона P0467 Низкий уровень сигнала датчика потока воздуха продувки P0468 Высокий уровень сигнала датчика потока воздуха продувки P0469 Перемежающийся уровень сигнала датчика потока воздуха продувки P0470 Неисправность датчика давления выхлопных газов P0471 Сигнал датчика давления выхлопных газов вне допустимого диапазона P0472 Низкий уровень сигнала датчика давления выхлопных газов P0473 Высокий уровень сигнала датчика давления выхлопных газов P0474 Перемежающийся уровень сигнала датчика давления выхлопных газов P0475 Неисправность клапана датчика давления выхлопных газов P0476 Сигнал клапана датчика давления выхлопных газов вне допустимого диапазона P0477 Низкий уровень сигнала клапана датчика давления выхлопных газов P0478 Высокий уровень сигнала клапана датчика давления выхлопных газов P0479 Перемежающийся уровень сигнала клапана датчика давления выхлопных газов P0480 Неисправность цепи управления реле вентилятора P0500 Нет сигнала датчика скорости автомобиля P0501 Сигнал датчика скорости автомобиля вне допустимого диапазона P0502 Низкий уровень сигнала датчика скорости автомобиля P0503 Высокий уровень сигнала датчика скорости автомобиля P0505 Неисправность регулятора холостого хода P0506 Неисправность регулятора холостого хода - низкие обороты P0507 Неисправность регулятора холостого хода - высокие обороты P0510 Closed Throttle Position Switch Malfunction P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance P0532 A/C Refrigerant Pressure Sensor Circuit Low Input P0533 A/C Refrigerant Pressure Sensor Circuit High Input P0534 Air Conditioner Refrigerant Charge Loss P0550 Power Steering Pressure Sensor Circuit Malfunction P0551 Power Steering Pressure Sensor Circuit Range/Performance P0552 Power Steering Pressure Sensor Circuit Low Input P0553 Power Steering Pressure Sensor Circuit High Input P0554 Power Steering Pressure Sensor Circuit Intermittent P0560 Напряжение питания системы ниже порога работоспособности P0561 Напряжение питания системы нестабильное P0562 Низкое напряжение питания системы P0563 Высокое напряжение питания системы P0565 Неисправность сигнала включения круиз-контроля P0566 Неисправность сигнала выключения круиз-контроля P0567 Cruise Control Resume Signal Malfunction P0568 Cruise Control Set Signal Malfunction P0569 Cruise Control Coast Signal Malfunction P0570 Cruise Control Accel Signal Malfunction P0571 Cruise Control/Brake Switch A Circuit Malfunction P0572 Cruise Control/Brake Switch A Circuit Low P0573 Cruise Control/Brake Switch A Circuit High P0574 Cruise Control Related Malfunction P0575 Cruise Control Related Malfunction P0576 Cruise Control Related Malfunction P0577 Cruise Control Related Malfunction P0578 Cruise Control Related Malfunction P0579 Cruise Control Related Malfunction P0580 Cruise Control Related Malfunction P0600 Serial Communication Link Malfunction P0601 Ошибка контрольной суммы ПЗУ P0602 Control Module Programming Error P0603 Ошибка внешнего ОЗУ P0604 Ошибка внутреннего ОЗУ P0605 Internal Control Module Read Only Memory (ROM) Error P0606 PCM Processor Fault P0607 Неисправность канала детонации P0608 Control Module VSS Output "A" Malfunction P0609 Control Module VSS Output "B" Malfunction P0620 Generator Control Circuit Malfunction P0621 Generator Lamp "L" Control Circuit Malfunction P0622 Generator Field "F" Control Circuit Malfunction P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction P0654 Engine RPM Output Circuit Malfunction P0655 Engine Hot Lamp Output Control Circuit Malfucntion P0656 Fuel Level Output Circuit Malfunction P0700 Неисправность системы контроля трансмиссии P0701 Система контроля трансмиссии вне допустимого диапазона P0702 Transmission Control System Electrical P0703 Torque Converter/Brake Switch B Circuit Malfunction P0704 Clutch Switch Input Circuit Malfunction P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input) P0706 Transmission Range Sensor Circuit Range/Performance P0707 Transmission Range Sensor Circuit Low Input P0708 Transmission Range Sensor Circuit High Input P0709 Transmission Range Sensor Circuit Intermittent P0710 Transmission Fluid Temperature Sensor Circuit Malfunction P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance P0712 Transmission Fluid Temperature Sensor Circuit Low Input P0713 Transmission Fluid Temperature Sensor Circuit High Input P0714 Transmission Fluid Temperature Sensor Circuit Intermittent P0715 Input/Turbine Speed Sensor Circuit Malfunction P0716 Input/Turbine Speed Sensor Circuit Range/Performance P0717 Input/Turbine Speed Sensor Circuit No Signal P0718 Input/Turbine Speed Sensor Circuit Intermittent P0719 Torque Converter/Brake Switch B Circuit Low P0720 Output Speed Sensor Circuit Malfunction P0721 Output Speed Sensor Range/Performance P0722 Output Speed Sensor No Signal P0723 Output Speed Sensor Intermittent P0724 Torque Converter/Brake Switch B Circuit High P0725 Engine Speed input Circuit Malfunction P0726 Engine Speed Input Circuit Range/Performance P0727 Engine Speed Input Circuit No Signal P0728 Engine Speed Input Circuit Intermittent P0730 Incorrect Gear Ratio P0731 Gear 1 Incorrect ratio P0732 Gear 2 Incorrect ratio P0733 Gear 3 Incorrect ratio P0734 Gear 4 Incorrect ratio P0735 Gear 5 Incorrect ratio P0736 Reverse incorrect gear ratio P0740 Torque Converter Clutch Circuit Malfuction P0741 Torque Converter Clutch Circuit Performance or Stuck Off P0742 Torque Converter Clutch Circuit Stuck On P0743 Torque Converter Clutch Circuit Electrical P0744 Torque Converter Clutch Circuit Intermittent P0745 Pressure Control Solenoid Malfunction P0746 Pressure Control Solenoid Performance or Stuck Off P0747 Pressure Control Solenoid Stuck On P0748 Pressure Control Solenoid Electrical P0749 Pressure Control Solenoid Intermittent P0750 Shift Solenoid A MalfunctionP P0751 Shift Solenoid A PerformanceP or Stuck Off P0752 Shift Solenoid A Stuck On P0753 Shift Solenoid A ElectricaPl P0754 Shift Solenoid A IntermittPent P0755 Shift Solenoid B Malfunction P0756 Shift Solenoid B Performance or Stuck Off P0757 Shift Solenoid B Stuck On P0758 Shift Solenoid B Electrical P0759 Shift Solenoid B Intermittent P0760 Shift Solenoid C Malfunction P0761 Shift Solenoid C Performance or Stuck Off P0762 Shift Solenoid C Stuck On P0763 Shift Solenoid C Electrical P0764 Shift Solenoid C Intermittent P0765 Shift Solenoid D Malfunction P0766 Shift Solenoid D Performance or Stuck Off P0767 Shift Solenoid D Stuck On P0768 Shift Solenoid D Electrical P0769 Shift Solenoid D Intermittent P0770 Shift Solenoid E Malfunction P0771 Shift Solenoid E Performance or Stuck Off P0772 Shift Solenoid E Stuck On P0773 Shift Solenoid E Electrical P0774 Shift Solenoid E Intermittent P0780 Shift Malfunction P0781 1-2 Shift Malfunction P0782 2-3 Shift Malfunction P0783 3-4 Shift Malfunction P0784 4-5 Shift Malfunction P0785 Shift/Timing Solenoid Malfunction P0786 Shift/Timing Solenoid Range/Performance P0787 Shift/Timing Solenoid Low P0788 Shift/Timing Solenoid High P0789 Shift/Timing Solenoid Intermittent P0790 Normal/Performance Switch Circuit Malfunction P0801 Reverse Inhibit Control Circuit Malfunction P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction P1000 OBD II Monitor Testing not complete P1001 Key On Engine Running (KOER) Self-Test not able to complete. KOER aborted P1100 Mass Air Flow (MAF) sensor intermittent P1101 Mass Air Flow (MAF) sensor out of Self-Test range P1102 Низкое сопротивление подогревателя датчика кислорода P1110 Switch over valve solenoid P1112 Switch over valve 1 P1113 Switch over valve 2 P1116 О2 Sensor heater Circuit (Open) Engine Coolant Temperature (ECT) sensor out of Self - Test range P1117 Engine Coolant Temperature (ECT) sensor intermittent P1120 Throttle Position (TP) sensor out of range low P1121 Throttle Position (TP) sensor inconsistent with MAF Sensor P1123 Long Term Fuel Trim Additive Air (System too Rich) P1124 Throttle Position (TP) sensor out of Self -Test range Long Term Fuel Trim Additive Air (System too Lean) P1125 Throttle Position (TP) sensor circuit intermittent P1127 Exhaust not warm enough, downstream Heated Oxygen Sensors (HO2Ss) not tested Long Term Fuel Trim Multiplicative (System too Rich) P1128 Upstream Heated Oxygen Sensors (HO2Ss) swapped from bank to bank Long Term Fuel Trim Multiplicative (System too Lean) P1129 Downstream Heated Oxygen Sensors (HO2Ss) swapped from bank to bank P1130 Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, adaptive fuel at limit (Bank # 1) P1131 Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, sensor indicates lean (Bank # 1)) P1132 Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, sensor indicates rich (Bank # 1) P1136 Long Term Fuel Trim Additive Fuel (System too Rich) P1137 Lack of downstream Heated Oxygen Sensor (HO2S 12) switch, sensor indicates lean (Bank # 1) Long Term Fuel Trim Additive Fuel (System too Lean) P1138 Lack of downstream Heated Oxygen Sensor (HO2S 12) switch, sensor indicates rich (Bank # 1) P1140 Неверный сигнал нагрузки P1150 Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, adaptive fuel at limit (Bank #2) P1151 Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, sensor indicates lean (Bank # 2) P1152 Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, sensor indicates rich (Bank # 2) P1157 Lack of downstream Heated Oxygen Sensor (HO2S 22) switch, sensor indicates lean (Bank # 2) P1158 Lack of downstream Heated Oxygen Sensor (HO2S 22) switch, sensor indicates rich (Bank # 2) P1171 Низкий уровень сигнала СО-потенциометра P1172 Высокий уровень сигнала СО-потенциометра P1174 02 Sensor 1 Bank 1 (period monitoring) P1176 02 Sensor 1 Bank 1 (tv monitoring) P1220 Series Throttle Control system malfunction P1224 Throttle Position Sensor B (TP- out of Self - Test range P1229 Power Supply Relay Primary Circuit Voltage High P1230 Power Supply Relay Secondary Circuit Voltage Low P1231 Fuel pump relay circuit low with high speed pump on P1232 Low speed Fuel Pump primary circuit malfunction P1233 Fuel Pump Driver Module disabled or offline P1234 Fuel Pump Driver Module disabled or offline P1235 Fuel Pump control out of Self - Test range P1236 Fuel Pump control out of Self - Test range P1237 Fuel Pump secondary circuit malfunction P1238 Fuel Pump secondary circuit malfunction P1260 THEFT detected - engine disabled P1270 Engine RPM or vehicle speed limiter reached P1285 Cylinder Head over temperature sensed P1288 Cylinder Head Temperature (CHT) sensor out of Self - Test range P1289 Cylinder Head Temperature (CHT) sensor circuit low input P1290 Cylinder Head Temperature (CHT) sensor circuit high input P1299 Engine over temperature condition P1326 Knock Control Maximum Spark Limit Cylinder 1 P1327 Knock Control Maximum Spark Limit Cylinder 2 P1328 Knock Control Maximum Spark Limit Cylinder 3 P1329 Knock Control Maximum Spark Limit Cylinder 4 P1351 Ignition Diagnostic Monitor (IDM) circuit input malfunction P1356 PIPS occurred while IDM pulse width indicates engine not turning P1357 Ignition Diagnostic Monitor (IDM) pulse width not defined P1358 Ignition Diagnostic Monitor (IDM) signal out of Self - Test range P1359 Spark output circuit malfunction P1386 Knock control Testpulse P1390 Octane Adjust (OCT ADJ) out of Self - Test range P1400 Differential Pressure Feedback EGR (DPFE) sensor circuit low voltage detected P1401 Differential Pressure Feedback EGR (DPFE) sensor circuit high voltage detected P1405 Differential Pressure Feedback EGR (DPFE) sensor upstream hose off or plugged P1406 Differential Pressure Feedback EGR (DPFE) sensor downstream hose off or plugged P1408 Exhaust Gas Recirculation (EGR) flow out of Self - Test range P1409 Canister purge valve power stage (malfunction) Electronic Vacuum Regulator (EVR) control circuit malfunction P1410 Canister purge valve power stage (high) Secondary air pump relay P1411 Secondary Air Injection system incorrect downstream flow detected P1413 Secondary Air Injection system monitor circuit low voltage P1414 Secondary Air Injection system monitor circuit high voltage P1425 Canister purge valve power stage (low) Цепь управления клапаном продувки адсорбера, замыкание на землю P1426 Цепь управления клапаном продувки адсорбера, обрыв P1442 Evaporative emission control system small leak detected P1443 Evaporative emission control system - vacuum system, purge control solenoid or vapor management valve malfunction P1444 Purge Flow (PF) Sensor circuit low input P1445 Purge Flow (PF) Sensor circuit high input P1449 Evaporative emission control system unable to hold vacuum (Probe) P1450 Unable to bleed up fuel tank vacuum P1452 Unable to bleed up fuel tank vacuum P1455 Evaporative emission control system control leak detected (gross leak) P1460 Wide Open Throttle Air Conditioning Cutoff (WAC) circuit malfunction P1461 Air Conditioning Pressure (ACP) sensor circuit low input P1462 Air Conditioning Pressure (ACP) sensor circuit high input P1463 Air Conditioning Pressure (ACP) sensor insufficient pressure change P1464 Air Condition (A/C) demand out of Self - Test range P1469 Low air conditioning cycling period P1473 Fan secondary high with fan(s) off P1474 Low Fan Control primary circuit malfunction P1479 High Fan Control primary circuit malfunction P1480 Fan secondary low with low fan on P1481 Fan secondary low with high fan on P1483 Power to fan circuit over current P1484 Open power ground to Variable Load Control Module (VLCM) P1500 Неисправность цепи реле топливного насоса P1501 Immobiliser No or Wrong Coding Реле топливного насоса - замыкание на землю P1502 Реле топливного насоса - замыкание на +12V Immobiliser No Signal P1503 Immobiliser Wrong Signal P1504 Idle Air Control (IAC) circuit malfunction P1505 Idle Air Control (IAC) system at adaptive clip P1506 Idle Air Control (IAC) overspeed error P1507 Idle Air Control (IAC) under speed error P1509 Цепь управления регулятором холостого хода, перегрузка P1512 Intake Manifold Runner Control (IMRC) malfunction (Bank # 1 stuck closed) P1513 Intake Manifold Runner Control (IMRC) malfunction (Bank # 2 stuck closed) Цепь управления регулятором холостого хода - замыкание на землю P1514 Цепь управления регулятором холостого хода - обрыв P1516 Intake Manifold Runner Control (IMRC) input error (Bank # 1) P1517 Intake Manifold Runner Control (IMRC) input error (Bank # 2) P1518 Intake Manifold Runner Control (IMRC) malfunction (stuck open) P1519 Intake Manifold Runner Control (IMRC) malfunction (stuck closed) P1520 Intake Manifold Runner Control (IMRC) circuit malfunction P1530 Air Condition (A / C) clutch circuit malfunction P1537 Intake Manifold Runner Control (IMRC) malfunction (Bank # 1 stuck open) P1538 Intake Manifold Runner Control (IMRC) malfunction (Bank # 2 stuck open) P1539 Power to Air condition (A / C) clutch circuit overcurrent P1541 Цепь управления реле бензонасоса, обрыв P1550 Power steering Pressure (PSP) sensor out of Self - Test range P1570 Обрыв цепи иммобилизатора P1600 Нет связи с иммобилизатором Reprogram or Replace Electronic Control Unit (ECM) P1601 ECM Box Temperature High P1602 Пропадание напряжения контроллера Knock control module P1603 Ошибка EEPROM P1604 Knock control unit P1605 Knock control unit P1606 Knock control unit P1612 Ошибка сброса процессора P1619 Electrical Thermostat Control powerstage (too high) P1620 Ошибка ПЗУ Electrical Thermostat Control powerstage (too low) P1621 Ошибка OЗУ P1622 Ошибка EEPROM Electrical Thermostat Control powerstage (Range/Perfomance) P1625 B(+) supply to ariable Load Control Module (VCLM) fan circuit malfunction P1626 B(+) supply to Variable Load Control Module (VCLM) Air Condition (A / C) circuit malfunction P1640 Knock control unit or Quad drive module P1650 Power Steering Pressure (PSP) switch out of Self - Test range P1651 Power Steering Pressure (PSP) switch input malfunction P1689 Ошибка памяти ошибок P1690 Check Engine fail (malfunction indicator lamp) MIL-on requestsignal (Malfunction) P1693 MIL-on requestsignal (High) P1701 Reverse engagement error P1703 Brake On/Off (BOO) switch out of Self - Test range P1705 Transmission Range (TR) Sensor out of Self - Test range P1709 Park or Neutral Position (PNP) switch is not indicating neutral during KOEO Self - Test P1711 Transmission Fluid Temperature (TFT) sensor out of Self - Test range P1728 Transmission slip fault P1729 4x4 Low switch error P1740 Torque Control unit P1741 Torque Converter Clutch (TCC) control error P1742 Torque Converter Clutch (TCC) solenoid failed on (turns on MIL) P1743 Torque Converter Clutch (TCC) solenoid failed on (turns on TCIL) P1744 Torque Converter Clutch (TCC) system mechanically stuck in off position P1746 Electronic Pressure Control (EPC) solenoid open circuit (low input) P1747 Electronic Pressure Control (EPC) solenoid short circuit (high input) P1749 Electronic Pressure Control (EPC) solenoid failed low P1751 Shift Solenoid # 1 (SS1) performance P1754 Coast Clutch Solenoid (CCS) circuit malfunction P1756 Shift Solenoid # 2 (SS2) performance P1761 Shift Solenoid # 3 (SS3) performance P1780 Transmission Control switch (TCS) circuit out of Self - Test range P1781 4x4 Low switch out of Self - Test range P1783 Transmission over temperature condition P1788 3-2 Timing / Coast Clutch Solenoid (3-2 / CCS) circuit open P1789 3-2 Timing / Coast Clutch Solenoid (3-2 / CCS) circuit shorted U1021 SCP indicating the lack of Air Condition (A/C) clutch status response U1039 SCP indicating the vehicle speed signal missing or incorrect U1051 SCP indicating the brake switch signal missing or incorrect U1073 SCP indicating the lack of engine coolant fan status response U1131 SCP indicating the lack of Fuel Pump status response U1135 SCP indicating the ignition switch signal missing or incorrect U1256 SCP indicating a communications error U1451 Lack of response from Passive Anti-Theft system (PATS) module - engine disabled
#15 zevszc
zevszc
  • 17 сообщений
Отправлено 03 Июнь 2012 - 10:59
Коды неисправностей стандарта OBDII
Огромное спасибо. Видел их раньше в нете но потом не смог найти. воттолько бы научится ими пользоваться))). но это уже другая история
