По-порядку:
1)
Стоимость
На примере
BMW X3 E83:
Оригинал перед 34 11 3 404 362 - порядка 100 евро
ATE 13.0460-7155.2 - порядка 50 долларов
ATE 13.0470-7155.2 CERAMIC BELAGSATZ SGL11 - порядка 110 долларов
На примере Е46:
Я очень давно не ставил колодки АТЕ по причине многочисленных жалоб на посторонние шумы, писк, качество изделий. Перешёл на оригинальные колодки, либо TEXTAR PAGID и все TMD Friction.
АТЕ Ceramic по цене схожи с оригинальными колодками, весьма доступная цена, если это так хорошо работает, т.е. уменьшает налёт на дисках, скрипы и другое, хотя оригинал диски и колодки не скрипят вообще.
2) Вся информация по АТЕ Ceramic есть на сайте www.ate-ceramic.com
The brake pad with the added benefits
low-dust – noise-free – long-life
Vehicle brakes convert kinetic energy into heat through friction. This produces wear. A clear indication of this wear is the black dust which accumulates predominantly on the rims, leaving behind unsightly marks. This is not just inconvenient for vehicle owners who place high value on the appearance of their vehicle - brake dust is also harmful to the environment.
Innovative brake pad compound
ATE Ceramic is Continental's solution for low-dust, noise-free, resource-saving and environmentally friendly braking. The secret of the new brake pads lies in a brake pad compound which uses innovative fiber technology During braking, it produces a "transfer film" on the brake disc. This protects the brake disc from excessive wear. The result: less brake dust, more comfort, less wear.
Clean rims, better appearance
The low-dust operation of the new ATE Ceramic brake pads ensures that valuable rims retain an attractive appearance for longer. Compared with conventional brake pads, the rims have to be cleaned much less frequently. This saves time and lowers consumption of expensive, environmentally harmful wheel cleaning agents and valuable drinking water.
Less wear, lower costs
Extensive comparison tests under tough everyday operating conditions have shown that ATE Ceramic brake pads are much less susceptible to wear than standard brake pads. They also significantly extend the service life of the brake discs. This reduction in wear reduces repair costs and saves drivers money. In addition, the transfer film has a positive effect on the corrosion behavior of the brake discs. As a result, ATE Ceramic brake pads have less tendency to rust tight under the influence of wet weather, road salt or during long idle periods.
Less noise, more comfort
The innovative brake pad compound in ATE Ceramic brake pads reduces noise development during braking. Annoying humming, creaking and squealing is effectively suppressed. This significantly improves braking comfort. Furthermore, ATE Ceramic brake pads prevent brake disc erosion. This puts a stop to brake judder and the associated steering flutter.
Very safe
ATE Ceramic brake pads exceed the strict requirements of the ECE R90 directives. During everyday usage conditions, they provide the same braking power and safety as standard brake pads. They are also fully compatible with vehicle dynamics control systems.
Active contribution to environmental protection
Since ATE Ceramic brake pads produce almost no brake dust, they reduce environmental pollution. Their better wear characteristics also save resources but with the same level of braking performance. Soiling of high-quality aluminum rims by brake dust is reduced to a minimum. This means that the frequency of cleaning procedures using brake dust-removing chemicals can be reduced significantly. ATE Ceramic brake pads thus make an active contribution to more environmentally friendly driving.
Easy retrofitting
ATE Ceramic brake pads do not require any modifications to the vehicle. They can simply be installed in place of standard brake pads during brake servicing. ATE Ceramic brake pads are available for numerous vehicle models from various automotive manufacturers. They are available both for the front and rear axle. The product range is being continuously expanded. In the near future, the majority of common vehicle models will be covered.
ATE Ceramic –Advantages at a glance:
- Significantly reduced dust development
- Practically noise-free
- Better rim appearance
- Less brake pad and brake disc wear
- Greater comfort
- No brake judder
- Better environmental protection
- Lower repair costs
- Very safe
