1000HP BMW E21 (S54)
Сообщений в теме: 11
#1 BeL.fy
BeL.fy
    Модератор
  • 4 589 сообщений
  • E34
Отправлено 11 Март 2013 - 08:59
1982 BMW 316 ENGINE 3.2L turbocharged S54 engine; CP 9:1 pistons; Pauter X-profile rods; ARP I19 head bolts, 2000 cam beraring bolts; head overhaul with OEM components; JAAS VANOS block off, headers, intake manifold, throttle cable conversion, intercooler piping, exhaust manifold, exhaust, muffler; PTE 7654 billet turbo; 60mm PPF wastegate, 75mm blow-off valve; BOSCH 1680cc injectors, 044 fuel pump (x2); NUKE fuel rail; 40L fuelcell; electric water pump; VW LT fan; Griffin aluminum radiator, Intercooler ENGINE MANAGEMENT Electromotive TEC GT ECU DRIVELINE BMW E39 Gearbox, E23 745i differential; Tilton 3-plate clutch; JAAS made driveshaft SUSPENSION / CHASSIS XYZ coilovers from E30 (welded to E34 M5 struts in front); E34 bear arms and caster struts, modified E21 front sub frame with E46 RHD steering pinion, BMW E28 535 rear subframe, custom diff mounting point triangulated to the roll cage. BRAKES Original E34 M5 brakes front and rear WHEELS / TIRES 17X8.5″ +15 (f) / 17X10″ +20 ® BBS RS mesh; 215/40-17 (f) / 235/40-17 ® Nankang tires CABIN Sparco Sprint seats; SRS 6-point harness; Sabelt steering wheel; Autometer Sport Comp tachometer, oil pressure, oil temperature, water temperature and boost gauges; hydraulic hand brake; floor mounted pedal set BODY Firewall moved 30 cm, larger custom transmission tunnel, compete roll cage welded to shock towers and rear sub frame mounts, rear fenders 4cm wider, custom trunk floor; yellow film on E34 headlights and blinkers PERFORMANCE 1000hp / 675lb-f @ 2 bar (29 psi)
#2 rostos
rostos
  • 1 590 сообщений
  • M3/// e46
  • СПб
Отправлено 11 Март 2013 - 09:26
1-ая 3-ка :good:
#3 LoMax
LoMax
  • 1 235 сообщений
  • 732i e23
Отправлено 11 Март 2013 - 09:28
??а чего всё на инглише??
#4 sniper.87
sniper.87
  • 162 сообщений
  • 735i
  • Bobruisk/Belarus
Отправлено 11 Март 2013 - 09:42
1982 BMW 316  ДВИГАТЕЛЬ  3.2L турбированный двигатель S54; CP 9:01 поршней; Pauter X-профиль стержней; ARP I19 болты головки, 2000 кулачком beraring болты, голова капитальный ремонт с элементами OEM; JAAS VANOS блокировать, заголовки, впускной коллектор, преобразования трос газа, интеркулер трубопроводов , выпускной коллектор, выпускной, глушитель; PTE 7654 заготовку турбо, 60мм PPF вестгейт, 75 выпускной клапан, форсунки BOSCH 1680cc, 044 топливный насос (x2); NUKE топливной рампе; 40L FuelCell, электрический водяной насос, вентилятор VW LT; Griffin Алюминиевый радиатор, интеркулер  Система управления двигателем  Электродвижущая TEC GT ECU  КАРДАННОЙ  Коробка передач BMW E39, E23 745i дифференциала; Tilton 3-сцепление; JAAS сделал карданный вал  Подвес / CHASSIS  XYZ койловеры от E30 (приварена к E34 M5 распорки спереди); E34 ношение оружия и заклинателя стойки, изменение E21 передний подрамника с E46 RHD реечный рулевой механизм, BMW E28 535 заднего подрамника, пользовательские изменению точки крепления триангулирована на каркас.  ТОРМОЗА  Оригинальный E34 M5 тормоза передних и задних  Колеса / шины  17X8.5 "15 (F) / 17x10" 20 ® BBS RS сетки; 215/40-17 (F) / 235/40-17 шины Nankang ®  CABIN  Sparco Sprint мест; SRS 6-точечные ремни безопасности; Sabelt руль; AutoMeter Спорт Comp тахометра, давления масла, температуры масла, температуры воды и повысить датчиков; гидравлический ручной тормоз, напольные педали установлены  BODY  Firewall переехал 30 см, больше пользовательских туннеля передачи, конкурировать каркас сварной башни к ударам и задней под крепления рамы, задние крылья 4 см шире, пользовательские пол багажника, желтая пленка на E34 фары и шорты  ПРОИЗВОДИТЕЛЬНОСТЬ  1000hp / 675lb-F @ 2 бар (29 фунтов на квадратный дюйм)
#5 Костя Кот
Костя Кот
    Черные-черные Х-ы
  • 6 602 сообщений
  • Х8=Х5+Х3
  • Минск/РБ
Гугл- транслейт и в путь, хотя и правда не удобно!
#6 BeL.fy
BeL.fy
    Модератор
  • 4 589 сообщений
  • E34
Отправлено 11 Март 2013 - 09:56
у меня просто гугл хром сам всё переводит так и забыл как то) долго пытался развернуть видео но так и не получилось что за фигня
#7 LoMax
LoMax
  • 1 235 сообщений
  • 732i e23
Отправлено 11 Март 2013 - 10:43
так а смысл тему создавать на английском или ломаном русском? Да и ничего особо выдающегося не вижу..имхо.
#8 BeL.fy
BeL.fy
    Модератор
  • 4 589 сообщений
  • E34
Отправлено 12 Март 2013 - 11:45
это можно отнести к половине тем
кому надо тот посмотрит и даже на анг поймёт
кому не надо тот вообще мимо пройдёт и ему будет пофиг
#9 lambus
lambus
  • 656 сообщений
  • 3-reihe (e46) coupe
Отправлено 12 Март 2013 - 05:12
Да Юрик, дзе твоя е21?
#10 BeL.fy
BeL.fy
    Модератор
  • 4 589 сообщений
  • E34
Отправлено 12 Март 2013 - 05:39
даже не знаю) может где догнивает уже) а может мега проект кто строит))) :)))
#11 lambus
lambus
  • 656 сообщений
Отправлено 12 Март 2013 - 05:52
Подари мне ее)))
#12 J.D.
J.D.
  • 359 сообщений
  • E36.Ink Coupe.
Отправлено 13 Март 2013 - 03:41
Да старушка зверь %) :good:
